Escalade ABS problem
Old Apr 28, 2010 | 07:49 AM
BoostedLade's Avatar
Default Escalade ABS problem
Alright I have a 2002 escalade. It went to the dyno the other day to get tuned. The tuner pulled the ABS fuse from under the hood before the dyno for saftey reasons. As i was driving home i noticted that when im at about 2-6mph and lightlty push the breaks the abs kicks in and i get no breaks. If i push really hard on the breaks it stops fine. The ABS light came on then goes off. Any suggestions on what might have happend?
Old Apr 28, 2010 | 09:51 AM
Caughtup07's Avatar
I know the pickups in those years had some problems with the sensors themselves. Rust builds up under the sensor and makes the sensor think that the brakes are locking which activates the abs at low speeds. The avalanche is basically the same thing so I would check that out. Why it happened after the fuse I'm not sure, maybe just coincidence.
Old Apr 29, 2010 | 09:15 PM
The abs sensors go bad. I've had mine replaced and I still have problems with it. my ABS light and my parking brake light comes on and my ABS goes out the window. Good luck with your issue.
RustyD
May 23, 2016 07:04 PM
dsbodley
Nov 14, 2015 09:46 PM
BCraven1018
Oct 1, 2015 08:22 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Blklgt
Sep 28, 2015 03:21 PM
