Engine swap = No start
Old Feb 7, 2006 | 03:29 PM
TchargedLS1TA's Avatar
Hmm, never thought to look there.. I did notice there is no hilighter for the gear select.. I will check it out..
Old Feb 7, 2006 | 04:43 PM
Colby 04's Avatar
Have you taken it out of park since the swap? That's odd that it doesn't indicate the gear.
Old Feb 7, 2006 | 04:44 PM
Yup, Ive gone through ever gear nd nothing happens...
Old Feb 7, 2006 | 05:05 PM
Post
Originally Posted by Colby 04
Some food for thought...
Neutral saftey switch...There was a guy on FSC that did a 6L swap, it wouldn't start, he had it towed to the dealer and they replaced the neutral safety switch. I'm not sure if the BCM would affect the vehicles ability to start and run
The BCM module does effect the engines ability to start and run.
Not saying that is the problem, but it's a possibility.
Did you also try starting it in different gear selections?
If there is no read out in the dash for the gear indicator, seems like something is definately wrong. There doesn't seem to be any power coming from the ignition being switched on. Does anything chime in the truck when the ignition is switched on?
Is it possible that the PCM was shorted out?
I'm thinking either PCM or BCM if all fuses are still good. Both are expensive and the BCM module would have to be reprogramed if you buy a new one or used one.
Double check all the wiring. Make sure the engine ground wire was attached as well. (A big forgetter here)
Hope you figure it out.
Jim
Old Feb 7, 2006 | 06:40 PM
ZDEN's Avatar
i broke my neutral safety switch while doing a conv install and the gear indicator did not light up. it would not do anything until i replaced the nuetral safety switch. check the plugs on it
Old Feb 7, 2006 | 08:07 PM
Found the problem to be a pinched PCM ground wire between the tranny and the block..
Old Feb 9, 2006 | 04:59 PM
FarmerBeau's Avatar
Sexy Party Mod
NICE!!!! Good job.
Bumpers
Aug 4, 2024 09:44 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
CammedZ71
Aug 2, 2015 01:44 AM
Ketis
Jul 23, 2015 12:37 PM
Deceptarado
Jul 8, 2015 05:24 PM
