effect of not having a 02 sensor?
Getting some long tube Pacestters installed and the 'mechanic' says im going to loose the 02 sensor and have a engine light come on . What is the effect on my engine good or bad?
He must be talking about the rear O2's, as there are bungs for the fronts. No biggie, you'll have a check engine light until you can get the PCM tuned and have the rear O2 sensors and accompanying codes turned off.
fugg it i dont run any o2 sensors except a wideband
