Efans & Alternator Size
Old 10-25-2013, 10:53 AM
jaawood's Avatar
Default Efans & Alternator Size
When you guys have changed to efans, have you gone to the 145A alternator as well, or kept the 105A?
Old 10-25-2013, 11:02 AM
BigDaddy0381's Avatar
200amp and not worry about it.
Old 10-26-2013, 02:11 AM
Suburbazine's Avatar
105 won't supply enough power to keep E-fans running.
Old 10-26-2013, 07:48 AM
whippled 8.1l build's Avatar
High Output 250Amp Alternator Chevrolet Avalanche 5 3L 03 04 | eBay
i used a 300 amp but this one would do ya
Old 10-26-2013, 08:58 PM
SnakeOiler's Avatar
I stayed with my 105amp alt. But it finally gave up after 180k miles, so I got the factory 130 amp
Old 10-26-2013, 10:12 PM
DUK713's Avatar
You guys that went to the 200 AMP or higher, did you go to a heavier gauge wire also?
Old 10-26-2013, 11:15 PM
Koots's Avatar
It's always a good idea to run heavier gauge wire when upgrading to a high amp alternator. The stock wiring on pretty much every vehicle I've ever seen has been relatively small or insufficient.
Old 10-27-2013, 11:02 AM
jaawood's Avatar
Thinking I will go with 250a alternator and a fuse kit, something like this:
High Output Amp Alternator 250 Amp Fuse Wiring Kit | eBay
Old 10-27-2013, 02:25 PM
Ferocity02's Avatar
I ran the 105A alternator for a couple years with efans and never had and issue. But I upgraded to a 145A unit when I upgraded the stereo and put in a sub. No point of a high output alternator unless you actually need it.
Old 10-27-2013, 02:27 PM
Koots's Avatar
Also a good time to do the rest of the "Big 3" upgrade (do a search, it's covered heavily around most forums) and also upgrade the major ground cables too.
Quick Reply: Efans & Alternator Size
