Efan tuning with hptuners help needed
Old 12-31-2015, 05:55 AM
chris99gmc's Avatar
Originally Posted by SnakeOiler
Pin 33 IS used on some of the 99-02 trucks for auto recirculation.
I don't know if that pin is positive or ground in that configuration, but I guarantee you it is a ground when you switch the setting to FAN#2 in HPTuners.
Sorry to bring this thread back, but it's actually one of the only posts for 99-02 pcm's that have correct(updated) info for elec fans..
Can you confirm that this is what the function of changing the parameter to Fan#2 does in the tune??? Switching the output on pin 33 to ground??
Does anyone know what the proper setting is for fan type with this setup on a 99-01? Should it be set to Analog cycling? Or Auxiliary fans? Or...?
Old 12-31-2015, 06:54 AM
Custm2500's Rude Friend
1FastBrick's Avatar
You need to enable the Fan settings from No Fans to Parallel Series Fans.
Under the AC parameters you need to change it from Auto Recirculation to Fan #2.
Hope that helps.
Old 01-02-2016, 10:15 PM
MidnightExpress99's Avatar
Originally Posted by zblee
this is what you need, there is no pin 33 , there is a wire to connect to AC wire.
where the 03+ harness has the pin 33
I used same harness. Pushed blue pin into pin 42 of the ecm and tapped the AC wire near battery junction box mine is a 99 now with 34" radiator and dual gt fans and ls1fans.com harness. Everything works great. Low speed kicks on both at 218, high at 225 or 125 psi on trans and single hi on when AC clutch kicks on.
Attached Thumbnails Efan tuning with hptuners help needed-20151223_143924.jpg   Efan tuning with hptuners help needed-20151223_143936.jpg   Efan tuning with hptuners help needed-20151223_143905.jpg   Efan tuning with hptuners help needed-fb_img_1450899427529.jpg   Efan tuning with hptuners help needed-20151223_115234.jpg
Old 01-18-2016, 06:58 PM
Snail Fab
Sevex's Avatar
Hope that helps.
Sooooo if I am reading this right, If I wire the fans up exactly like the picture the OP posted (with it wired to pin 33 and not tapping into the A/C wire) and switch fan settings AND A/C parameters it should work with a 99-01 ECM??
Or will I still need to use Pin 42 and Tap into the A/C wire (instead of pin 33) to get it to work?
Old 01-20-2016, 10:45 AM
To my understanding and experience, I just did them on mine, I had to tap into the AC wire bc pinout differs slightly for the 03+ trucks. I did mine on 99. Dual GT truck fans, ls1fans.com harness. Pin 42 and tap ac wire. Ground point on pass side core support sucked to I cut it and grounded back to where harness grounds out on ALT bracket
ZONES89RS
21
09-24-2015 05:58 PM
Bluecollar Hotrods
07-16-2015 08:52 PM
Aboss
07-09-2015 10:28 AM
Sbrown06
07-09-2015 09:21 AM
Quick Reply: Efan tuning with hptuners help needed
