E85
E85 isn't a good alternative in a N/A engine. In a boosted engine it is the only pump gas to run. I can promise once you go E85 or even a custom E50 blend for track only purposes you wouldn't go back to 91.
It's good for a high compression engine also, because of the high octane rating.
It will run quite rich, as E85 has a lower stoich AFR.
Yes, it will be able to run more timing with the higher octane of the fuel.
Ive got two for you.
1) in a stock 04 6.0L gmc can i run E85? only reason i ask is because the station in town just got it. They have it for $2.50 a gallon. regular is $3.50 a gallon... I only get 11 mpg so the extra $1.00 will ad up over a month i drive 3500 miles a month.
2) you all said it would be good for boosted motors or ones with high compression. My vette is about 13:8-14.8 compression. I run straight leaded 110-112 in now. Would i benifit from the E85 straight or mixing with the leaded.
