DTC problem
Old 09-15-2006, 04:05 PM
Default DTC problem
My ABS and Parking Brake lights have been coming on a fair amount lately. I scanned for DTC's and it brought up C0265. Any idea what this one is?
Old 09-15-2006, 09:52 PM
anyone?
Old 09-15-2006, 10:20 PM
Grumpy5.3's Avatar
here is a bulletin about it,
Subject: ABS Light On, DTCs C0265, C0201, U1041 Set and/or Loss of Communication with Brake Module (Reground EBCM Ground) #04-05-25-002C - (11/23/2005)
Models: 2004-2005 Buick Rainier
2002-2006 Cadillac Escalade, Escalade EXT
2003-2006 Cadillac Escalade ESV
1999-2006 Chevrolet Silverado
2000-2006 Chevrolet Suburban, Tahoe
2002-2006 Chevrolet Avalanche
2002-2005 Chevrolet TrailBlazer, TrailBlazer EXT
2003-2005 Chevolet SSR
1999-2006 GMC Sierra
2000-2006 GMC Yukon, Yukon Denali, Yukon XL
2002-2005 GMC Envoy, Envoy XL
2002-2006 GMC Sierra Denali
2004-2005 GMC Envoy XUV
2002-2004 Oldsmobile Bravada
This bulletin is being revised to provide further diagnostic information and add 2006 model year full-size vehicles. Please discard Corporate Bulletin Number 04-05-25-002B (Section 05 -- Brakes).
Condition
Some customers may comment that the ABS light is on. Upon further inspection, DTCs C0265 and C0201 may be set in the brake module. It is also possible for DTC U1041 to set in other modules. There may also be a loss of communication with the brake module.
Cause
A poor connection at the EBCM ground is causing unnecessary replacements of brake modules.
Important: The EBCM Ground is different for each application. Refer to the list below for the proper ground reference:
• Midsize Utilities = Ground 304
• SSR = Ground 400
• Fullsize Trucks and Utilities = Ground 110
Correction
DO NOT REPLACE THE BRAKE MODULE.
Perform the following steps to improve the connection of the EBCM Ground:
Remove the EBCM Ground. The EBCM Ground is located on the frame beneath the driver's side door. If multiple grounds are found in this location, the EBCM ground can be identified as the heavy (12-gauge) wire.
Clean the area, front and back, using a Whiz Wheel®.
Install the ground, then the washer and then the bolt to the frame.
Important: It is important to use the bolts, washers and nuts specified in this bulletin. These parts have been identified due to their conductive finish.
Install a washer and nut to the back side of the frame.
Tighten
Tighten the nut to 9 N·m (79 lb in).
Cover the front and back side of the repair area using Rubberized Undercoating.
If that doesnt fix it, then you have an internal ebcm fault!!!
Brian
madmann26
04-29-2020 09:17 AM
dsbodley
11-14-2015 09:46 PM
2002_Z28_Six_Speed
10-04-2015 01:34 PM
02AWDAWSDenali
10-01-2015 05:08 PM
sTNT971
09-26-2015 06:27 AM
Quick Reply: DTC problem
