door seals noisy????
I have an 05 z71 extended cab. the door seals (weather stripping) seem to not be sealing all the way. When I drive down the road it is ridiculously noisy in my cab. Anyone ever have this problem or know where to get a good set of seals to fix it? Thanks.
ok i will check it when i get home but when driving down the road it is noisiest right in the front upper hand corner of the passeneger front door. that and I have a noisy pulley or bearing in the belt system, only when wet or cold though.
From: as far away from Koonerville as humanly possible
I bought my '08 used a few months back and the door seals squeaked like crazy, drove me nuts on backroads! Whoever had it before me must have been using armor all or something to "lube" the seals. There was a lot of crud built up on the rubber and door frame mating surfaces. I soaked rags with rubbing alcohol to clean off all the crud and then hit the rubber with silicone spray and wiped it in good. It made a world of difference, almost no squeaks at all now.
bagged7104SS
22
Oct 24, 2015 06:14 PM
RS/SS 4.8
Sep 17, 2015 09:17 PM
