Doing the Corvette Servo but what about???
Old Jul 26, 2016 | 09:22 AM
druff's Avatar
Sunshell is almost always a downfall of the 4l60.
But if he really spent 3 grand on it, it should be bullet proof. I only have 700 in mine but I also did the work myself so that's all parts
Old Jul 26, 2016 | 09:31 AM
RA62025's Avatar
Banned
Yeah he had it done by a transmission shop all they did was GM Trannys.
Ok this is where I'm at:
1. I'm doing the corvette servo
2. I'm doing the shift kit if it doesn't need a retune because I just tuned the truck or is it worth it?
3. If it is worth it I'll do the Servo and get the Shift Kit and have it tuned when I get my 3.73-4.10 gears probably in winter this year.
Sounds like a plan to you guys?
Old Jul 26, 2016 | 09:45 AM
About20ninj45's Avatar
I could be wrong, but when you get it tuned from places like that, I've been told ask they do is increase line pressures n the trans. Supposedly, you don't want high pressures with the vet servo. Can anyone confirm that?
Old Jul 26, 2016 | 02:58 PM
RA62025's Avatar
Banned
That's a good question
Old Jul 26, 2016 | 03:01 PM
druff's Avatar
1. Shops get expensive fast when it comes to trannys, so it might not be as tough as I originally thought.
2. No retune is required for the shift kit. At least it didn't for mine. And it is totally worth it.
3. I don't care what anybody says you can do with the pcm. It will never out perform a mechanical upgrade longer. Meaning you might get the same pressures but it's not designed to operate at those pressures.
Old Jul 26, 2016 | 03:24 PM
RA62025's Avatar
Banned
So if my pressures were messed with in the tune I just got I would need to have put put back before the shift kit and servo or just the servo?
Old Jul 26, 2016 | 03:27 PM
druff's Avatar
I'd but the transmission programming back to stock
Old Jul 26, 2016 | 06:20 PM
madmann26's Avatar
Despite popular belief, a built trans still needs tuning.
The largest problem with a stock program is in the FMC table.
If you look at the 100% table, it'll say 1235 or something similar. This is bad as the higher milliseconds tell the pcm to command less pressure. The 100% table in its stock form is bleeding off all pressure at 100% throttle.
Pretty sure that's bad, even for a built trans.
Old Jul 26, 2016 | 09:06 PM
Wolftrk99's Avatar
Needs to be tuned for multiple reasons, even after a shift kit to turn tm off and reduce effects of trans adapts... The pcm in stock form is designed to give a nice soft shift that you hardly feel.... And adding a shift kit increases line pressures, shortens shift times and basically does everything the pcm is trying to hide....
Old Jul 27, 2016 | 08:50 AM
RA62025's Avatar
Banned
Ok so I need to get it tuned for a shift kit but what about a Corvette servo only?
