did the e fan override and my abs light is on?
Old Aug 11, 2010 | 09:27 PM
liftedwhite94's Avatar
Default did the e fan override and my abs light is on?
everything is working fine but the abs and parking brake is on.. anything i might have hit under the hood? any ideals
Old Aug 11, 2010 | 09:34 PM
Atomic's Avatar
I have a gauge for that
Thats odd... didnt cut any other wires did ya?
Old Aug 11, 2010 | 09:39 PM
naw but i did hook up to the wrong 33, didnt know you hook up one pin on one side and the other side the other one goes. dont know if that has anything to do with it.. I took the battery cable off, going to let it sti for a few and put it back on
Old Aug 11, 2010 | 09:46 PM
Atomic's Avatar
huh? Should have used wire taps and just crimped it on to the wire from the pcm and put in a long wire to the switch on the other side of the crimp. The pins on the PCM are labeled and red and blue should be obvious...
Old Aug 11, 2010 | 09:47 PM
neither of my wires on either 42 or 33 was red or blue on either side and I did just crimp the wires, but I crimped on to the 43 and 33 on the same side that unplugs from the PCM, didnt know you had to crimp 43 on the one closest to the red and 33 on the other one
Old Aug 11, 2010 | 10:13 PM
BTW atomic thanks for all the help
Old Aug 11, 2010 | 10:41 PM
Atomic's Avatar
No no no, the big plastic connectors on the PCM. There are 2 of them; one is red, the other is blue. Per the diagram, you need pin 42 on the blue connector, and pin 33 on the red connector. The color of the actual wires should be dark green and dark blue...
Old Aug 12, 2010 | 09:56 PM
I didnt catch on to that at first and hooked up both wires on the same plastic piece, think it could have messed up anything? My ABS and parking brake light is still on.. bugs the crap out of me
Old Aug 13, 2010 | 11:45 AM
BigDell's Avatar
My truck is doing the same thing but i had my truck tuned after that the both light came on. like to know when you get yours fixed what made your light come on. Want have a chance to get my truck looked at until next week i don't think its nothing major cause my truck is running like a champ and braking good to.
Old Aug 13, 2010 | 05:14 PM
any ideals?
