Custom Heat Extractor/Meacham
Old Jul 26, 2009 | 04:47 PM
  #21
fastnblu's Avatar
Originally Posted by dhpro
...U can spray an anti corrosion treatment on the bare metal if you dont plan to paint immediately. Key is to leave as little bare metal UNDER the extractor as possible as thats gonna be hard to treat/paint to prevent rust...R/
Yes, I know; didn't know if u did. I forgot what PPG calls it, Dupont calls it Variprime. Both designed for bare metal. If forced to blast, u could tape off w/ several layers of masking tape near area where u need to do that 1/2"-1", to minimize sand from contacting surrounding area. Then blast what u need, remove tape, then go from there.
On areas that are welded, there is a similiar treatment, a weld thru coating if u will. Same purpose, to prevent rust formation, when welding is necessary.
Old Aug 2, 2009 | 04:56 PM
  #22
dhpro's Avatar
Temporary fitment of drainage trays:
Put the extractors on top of them and sprayed baby powder to make sure the trays were properly positioned.
Dotted line is cut point to alter for center drainage. Once I do proper measuring I make the changes with some fibreglass and direct it onto the rad shroud or just behind the fans...
Plastic screws and washers will create the proper angles of flow towards the drainage. Starting to drill the holes for the extractors next...very scarey to put holes in my hood! Drilling them from the bottom to avoid cutting the ribs...done about half so far...pix will be up when its done. Be a real prob if I cut thru a rib or outside where the extractors/trays support them! I hate doing stuff myself - u only ever see the mistakes, but its better than paying for **** work I guess!
Old Aug 9, 2009 | 08:47 PM
  #23
dhpro's Avatar
Vent Holes drilled...progress is slow, but movin along...
Old Oct 19, 2009 | 08:40 PM
  #24
dhpro's Avatar
Update: extractors glued on! Not all that tough except I almost passed out from the glue fumes!
More pix in my sig...
Old Oct 20, 2009 | 03:07 PM
  #25
12 Second Club
be cool to see it finished and painted...
Old Oct 20, 2009 | 07:38 PM
  #26
fastnblu's Avatar
dhpro, looks like it comin along. Keep up the good work!
I see u have your current transportation in front of hood in 3rd pic while Avy is down.
Old Nov 2, 2009 | 08:29 AM
  #27
dhpro's Avatar
Body work continues...slowly. The time will be spent making the edges all uniform and straight. It wud definately be easier to blend them in! R/
Old Nov 2, 2009 | 11:23 AM
  #28
budhayes3's Avatar
PT's Slowest Truck
Coming along nicely!
Old Mar 20, 2010 | 06:04 AM
  #29
dhpro's Avatar
Time to get this going again! Havent touched it all winter...
Old Aug 3, 2010 | 10:13 AM
  #30
dhpro's Avatar
Finally finished!
Water Trays:
