Cooling capacity
Old Jun 25, 2006 | 03:09 PM
RGMEPP's Avatar
Default Cooling capacity
So the stroker has 1000 mi on it, and has never overheated. The one thing I don't like is that it does not hold near the 160 deg. stat. setting. Radiator has been cleaned, and all fins bent over have been straightened. We are running 25% under, which could be a culprit. Also, running the 5500 cfm flex-a-lite fans. Had thoughts of a thicker radiator. Stocker seems to have room for more core. Would I find this in a 3500 radiator, or some heavier duty cooling option for the 2500 HD. part #'s ??? Anything good out there on the aftermarket ???????? Want everything right before a Nelson tune.
Old Jun 25, 2006 | 03:19 PM
TouchOfEvil04's Avatar
Not that this helps really...but i have a 160 stat and run at 179 all day long....
Old Jun 25, 2006 | 04:20 PM
jmproductions's Avatar
Yeah I don't think your engine will realistically run much under this no matter what thermo you run. I really doubt 160* would be an efficient operating temp anyway. You could try running Redline Water Wetter with a much smaller ratio of antifreeze/water and this should help you run a bit cooler if you haven't tried it yet.
Old Jun 25, 2006 | 04:22 PM
Ya from what i have heard from almost everyone it will never see 160...
Since thats too cold anyway i'm fine with the 179*
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
Lthompson
Oct 2, 2015 12:45 AM
carid
Oct 1, 2015 09:22 AM
Wrecker 426
Sep 30, 2015 09:39 PM
