Console + Megashifter
#23
LS1Tech Whore
Originally Posted by 03lowriderss
correct me if im wrong but the color or the new console and glove box area is not the same as the rest of the trucks interior.
lol yeah i want to get all my interior painted or dyed black w/some silver. Not ready for that though.
#24
Originally Posted by Quik
one your talking to zippy.....
second there is no reason to manually shift a 60e. the computer does all the work for you. unless your on a stock tune
as for N20 tune thats easy have it set for the spray, when NA have it set for NA..if its a combo then set it at oen pont
older trans that would benefit with a 60e there is no reason at all
Thanks Quick.
He's honestly right. If you have the programming correct you never have to force a downshift or command it when to upshift. On the newer trucks if you want a different shift point for use with nitrous you could just set up a different shift patter in the tow/haul mode and run that mode for when you are spraying. Manually shifting a 60/65/70E trans on a regular basis is just a quick way to kill it. On an older trans that isn't even electronicly shifted you should set your shift points by adjusting the governer shift speed, not by manaully shifting it.
I think its awesome lookin!
