column shifter wiring help
Old Nov 2, 2008 | 07:54 PM
Deckhand's Avatar
Default column shifter wiring help
I removed my column shifter as I transplanted a th400 in my truck.. however, there is a thin green/white stripe and black pair of wires on the top of the column area .....and on the lower end of the steering column is a similar but thick green/white strip and black pair of wires are there. What is the purpose or function of those? thanks!
Old Nov 2, 2008 | 08:35 PM
StrokerAce03's Avatar
Tow/Haul maybe?
Old Nov 2, 2008 | 09:07 PM
Deckhand's Avatar
Originally Posted by StrokerAce03
Tow/Haul maybe?
tow haul was a orange wire. these were connected to some sort of microswitch if I remmeber correctly
Old Nov 2, 2008 | 09:18 PM
Oh ok; I was thinking the tow/haul was a green wire from the last time I looked at it but I guess not.
Old Nov 2, 2008 | 10:04 PM
TurboJohn6's Avatar
I do not remeber the color of the wires but you have the ones that go to the lock cylinder for the Passkey theft deterent. I believe you also have a wire for the brake/gear shift lock-out. It has been a while since I had mine apart so I cannot be more specific for you. Hope this helps you a little.
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
