Code P0757
Old Apr 20, 2005 | 09:36 PM
eurosys's Avatar
Default Code P0757
Does anybody know how to fix this code?
Old Apr 20, 2005 | 09:43 PM
BlownChevy's Avatar
blownerator
25 Year Member
I think that is a shift solenoid code. I am not sure what the fix is, I am sure someone will chime in.
Old Apr 20, 2005 | 09:44 PM
2000 SILVERADO's Avatar
I don't know how to fix it, but it has something to do with the tranny shift solenoid.
Damn, you beat me to it.
Old Apr 20, 2005 | 10:25 PM
eurosys's Avatar
Thanks Brian,
Like always, you are on target. It happens "sometimes only" when shifting from drive to reverse. The motor just stall. Truck still on warranty, going to the Dealer tomorrow.
Old Apr 20, 2005 | 10:28 PM
eurosys's Avatar
Second Thanks for 2000 Silverado. He was quicker because he has a Radix.lol
Old Apr 21, 2005 | 12:00 AM
02sierraz71_5.3's Avatar
https://ls1tech.com/forums/showthrea...27#post2778327
Old Apr 21, 2005 | 09:28 PM
v8
17,16,15,14,13,12,11 Drvr
shift B solenoid just reset code and see if it comes back again, mine did the same thing today and i just reset it and hasn't come back on yet lol The reason it might have stuck is a lack of voltage or a surge in voltage or if you reset the code and it comes back on then its bad.
Old Apr 21, 2005 | 11:29 PM
eurosys's Avatar
v8,
The problem is not the code, the problem is the engine sometimes just die by switching from drive to reverse. When it happens then it shows the P0757 code. By clearing the code it wont solve the real problem.
Old Apr 22, 2005 | 09:02 PM
negativeswitches's Avatar
DTC P0757 Set, SES Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping (Clean Transmission Valve Body and Case Oil Passages of Debris) #01-07-30-038B - (01/26/2004)
1999-2004 Passenger Cars and Light Duty Trucks
2003-2004 HUMMER H2
with 4L60-E/4L65-E Automatic Transmission (RPOs M30/M32)
This bulletin is being revised to add model years and change Cause and Correction information. Please discard Corporate Bulletin Number 01-07-30-038A (Section 07 - Transmission/Transaxle).
Condition
Some customers may comment on any of the following conditions:
* The SES lamp is illuminated.
* No 3rd and 4th gear.
* The transmission does not shift correctly.
* The transmission feels like it shifts to Neutral or a loss of drive occurs.
The vehicle free wheels above 48 km/h (30 mph). High RPM needed to overcome the free wheeling.
Cause
The most likely cause is chips or debris plugging the bleed orifice of the 2-3 shift solenoid (367). This will cause the transmission to stay in 2nd gear when 3rd gear is commanded and return to 1st gear when 4th gear is commanded.
DTC P0757 may also be set if the 2-3 shift valve (368) or 2-3 shuttle valve (369) were stuck, restricted and/or hung-up in its bore.
Correction
* Inspect / Clean the 2-3 shift valve (368), the 2-3 shuttle valve (369) and the valve bore of debris / metal chips.
* Inspect / Clean the 2-3 shift solenoid (367) opening of debris / metal chips. While inspecting the 2-3 shift solenoid (367), look for a screen over the solenoid opening. If the solenoid DOES NOT have a screen, replace the solenoid with P/N 10478131 that does have a screen over the solenoid opening.
Refer to the appropriate Service Manual for additional diagnostic information and service procedures.
