Which cluster???
Old Sep 11, 2010 | 07:09 PM
dlstewart01's Avatar
Originally Posted by fastnblu
Are u positive on this? Reason I ask is, I was told to get my model yr. cluster or it will not function propeerly. Or does it throw a code?
I'd like 1 that has the DIC if possible. I thought that '05 or '06 had a DIC that I could instantaneous MPG & tells oil lifew remaining. I don't really care what else a DIC would do, I'd just like those 2 features.
Plus the 2 newer yrs. change the PRNDL look.
04 was the last year for instant MPG. 05 does not have it. To get the dic function you will need the steering wheel with the controls on it. And clock spring part # 26101829. The dic will have to be programmed in the cluster if it does not already have it. otherwise the cluster with trans temp is plug and play. of course the mileage needs to be programmed in the cluster as well.
Old Sep 11, 2010 | 07:20 PM
outlawz2004's Avatar
I have an 06 ss intimidator cluster in my 04, no problems what so ever.
Old Sep 11, 2010 | 07:27 PM
fastnblu's Avatar
Here I thought an '06 would have it. Wait a minute, my sis-law had an '06 HD w/. a DIC. Or did the HD's get a different cluster pkg. And yes, that had the steering wheel u speak of. Which I'm not crazy bout, no offense if u have that on your GMC. I'll guess to program DIC into cluster, I'd need someone w/. a Tech2.
Thanks outlawz2004, so I got some bad info.
Old Sep 11, 2010 | 07:28 PM
RibeiroBJJ's Avatar
Praise The Lowered
I have a 06 denali cluster in my 01...plug n play...As far as the DIC I dont know,and the PRNDL in 06/07 changed to white led but still works iirc
Old Sep 11, 2010 | 07:33 PM
They will have the dic its just the instant MPG was dropped after the 04 model year..
You need the steering wheel controls and the clock spring to make the dic work if your truck did not come with them.
heres what the 05 and up will have...
RibeiroBJJ's Avatar
Praise The Lowered
Originally Posted by outlawz2004
No, not 99-02. 03-07 classic only
Your right..fixed,too many numbers in my head..typing too fast..lol
Old Sep 11, 2010 | 07:42 PM
fastnblu's Avatar
Ribeiro, while I wasn't aware of the white LED on the 06-07 PRNDL, I meant that on my '04, the PRNDL is separate from the speedo part. Later than '04, it has more of integrated look, since PRNDL is together w/. speedo & they slant the writing vs. the bold square look that mine has.
Old Sep 11, 2010 | 07:48 PM
fastnblu's Avatar
I knew I shoulda bought a blue '04 Sierra instead.
I almsot did.
So, could I just get steer wheel controls, or do I need a the whole column?
By controls, I'm thinkin, you're sayin, I'd just need that top part between steering wheel. Not the rest goin down, where the top 1/2 attaches. What the heck is a clockspring?
Old Sep 11, 2010 | 08:13 PM
here are the instructions to add the dic function and UK3 redundant radio controls...
http://www.jrrod2004.com/silverado/index.html
also...
http://www.gmfullsize.com/forum/showthread.php?t=144071
And I have done this to my truck....it looks harder than it actually is...
Old Sep 11, 2010 | 08:36 PM
fastnblu's Avatar
also...
And I have done this to my truck....it looks worse than it actually is...
Thanks for the links. If I (or anyone) wanted to do this w/. GM parts, these 2 links help. Or if aftermarket, I know Autometer came out w/. a Gas Gauge if that was all I was after, but it is only for specific vehicles /yrs.
Or just watch my tach & add a boost gauge w/. vacuum.
