Charging issue
Old Jun 20, 2012 | 03:07 PM
sprayedenali's Avatar
Default Charging issue
Alternstor checks out good, all wiring is good, battery is good but it only makes 12 volts. Then when I unplug the alternator it goes to ten volts. Any ideas?
Old Jun 20, 2012 | 03:31 PM
nonnieselman's Avatar
have you tried another battery?
Old Jun 20, 2012 | 03:45 PM
Can't say that I have. But it reads 12.5-13 volts with nothing turned on
This is also the second time this has happened recently. Had a big alternator on the truck for a while then it quit charging so I threw the sticker back on and it worked for a while then quit charging as well
Old Jun 20, 2012 | 04:13 PM
Id try another battery, and then if that doesnt work it has to be the alternator.
Old Jun 20, 2012 | 04:15 PM
my buddys TBSS just wouldnt crank the other night.. head lights were nice and bright everythign worked, battery had 12.5Volts. but it would just click the starter relay.
I took a battery out of my truck and put it in there, vola, cranked right up. Battery had a dead cell in it. and wouldnt take a load.
Old Jun 20, 2012 | 06:09 PM
It cranks fine. Just has low voltage when it's running. Tried another PCM, thinking mine might not be sending a good signal, and that didn't change anything. Had another battery hooked up and no difference.
Idryfly5
Sep 2, 2022 08:55 PM
kalikid06
20
Oct 13, 2015 07:37 AM
murderedSS
27
Oct 12, 2015 11:13 AM
dselby25
Sep 11, 2015 05:03 AM
Boyes50
Sep 8, 2015 12:06 PM
