Cabin Filter
Old Aug 17, 2009 | 08:13 PM
qwk93ta's Avatar
Do the 09s have one?
Old Aug 18, 2009 | 08:10 AM
shandy294's Avatar
Silver Dog: So the '04 has one but it's hard to get to? I know the part is out there...called AZ and O'Reilly and saw it at Wal Mart.
00Silv4.8: The 2000s have them in the passenger kick panel area,I believe. The '09...don't know.
Old Aug 18, 2009 | 08:27 AM
LowBlack99's Avatar
99-04 Trucks and suvs have them. They are not hard to replace at all! You do not have to remove the dash as stated earlier! Follow instructions given in post #2 and it should only take about 5-10 minutes. I can do it in 2!
Edit:some 04's do not have a cabin filter.
Old Aug 18, 2009 | 09:23 AM
shandy294's Avatar
Thanks,I'll check that area.
Old Aug 18, 2009 | 10:00 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Originally Posted by viciousknid
I've been considering changing mine on my '03 and was wondering what else I should do to get rid of the dirt smell when the A/C first engages. Should I take the filter out and blow compressed air bout up through it or what would you suggest?
Figured I'd throw it in since your on the topic
Some ideas:
http://www.pacificp.com/forum/viewtopic.php?t=8942
Old Aug 18, 2009 | 11:25 AM
LowBlack99's Avatar
PASSENGER COMPARTMENT AIR FILTER REPLACEMENT
REMOVAL PROCEDURE
edit: there was supposed to be a diagram here, guess it didnt copy.
If equipped, remove the Instrument Panel (I/P) sound insulator. (2 7MM Screws, fancy name for the black plastic cover)
Remove the filter access door screw. (5.5mm screw)
Remove the filter access door (1) from the HVAC module.
Remove the passenger compartment air filter (2). (there are 2 filters be sure to remove both)
Old Aug 18, 2009 | 11:33 AM
TX Tahoe Z71's Avatar
So dumb question, is there an easy way to tell if I have the filter(s) on the tahoe in my sig before pulling the dash off?
Old Aug 18, 2009 | 11:42 AM
Neil 6.0's Avatar
You don't have to pull the dash out.
Watch this (skip ahead to 0:50).
http://www.youtube.com/watch?v=bml8dletNbk
Old Aug 18, 2009 | 11:59 AM
Sorry, I misspoke... I meant before I remove the Instrument Panel sound insulator... "dash" was just easier to type.
Old Aug 18, 2009 | 12:07 PM
LowBlack99's Avatar
Call the dealer with your vin and ask. Or just remove the 2 screws and look. 03 will have them its 04 GM couldn't make up there mind. Also some 04's have fuel filters and some do not.
