A/C non responsive
I'v been having exactly the same prob. I found some blown body control fuses, but nothing improved. Its wierd, it works diff at each key in...sometimes runs in "default" only blowing thru the defrost vents, other times only hot, other time hot on pass only, then another it'll work. Of course the dealer didn't have a clue, so I told them to order a new head unit...still waiting...
Hey TORQUE_WRENCH...I aLso have been getting intermittant msgs on the display. First my 4wd was flashing service and got stuck in awd, and now its telling me to service air bags. Every once in a while I get 'engine reduced power' and the TB won't respond...are these systems related...is the a BCM relay I shud be lookin at? Thot I had a ground or loose wire prob, but nothing I cud find so far...suggestions?
Oh see right here, it might help if the problem is still there after you install the new unit
https://www.performancetrucks.net/fo...d.php?t=422918
Where's the Beef?
Well. I knew it was releated to my PCM swap. I got a new unit from another member and when I was putting it in I decided I'd give my unit 1 more chance, so I didn't throw away a good unit.
I unplugged it from the dash for a few seconds and plugged it back in and it started working. That was the only thing I hadn't tried yet.
So now I have a spare.
FlowmasterMufflers
Sep 18, 2015 02:31 PM
FormulaZR
Sep 14, 2015 05:23 PM
Hpinnovate
Sep 4, 2015 02:28 AM
