A/C compressor messed up?
Old Jan 15, 2006 | 10:22 AM
12sec.5.3's Avatar
Default A/C compressor messed up?
While driving down the road the compressor kicks on and off.I think that's normal but when it kicks on it squeals like the belt is slipping. Just the other night I was cruising and the a/c belt just comes off for no reason!!! Anyone know about this???
Old Jan 15, 2006 | 11:24 AM
1TRUESS's Avatar
My A/C is messed up too. I can ONLY turn it on with EFILive Bi-controls, and when I do there is a loud squeal grinding noise. My belt is just fine though?! Let me know what you find out.
Old Jan 15, 2006 | 11:45 AM
SnakeOiler's Avatar
Sounds like it was either not tight enough or misaligned.
Old Jan 15, 2006 | 03:31 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Had a GM Service Center in Harvey, LA replace my compressor twice, and they found out Detroit had a 2nd revision. Hadn't had problems since. Hadn't even hit 36K miles. Would make loud grinding noises, and increased when accelerating.
Just thought I'd throw that in there...
Old Jan 15, 2006 | 09:06 PM
budhayes3's Avatar
PT's Slowest Truck
A couple different things can cause that...the cycling on and off is normal, unless it is constant on and off due to low refrigerant. As far as throwing the belt, that could be from:
1) Incorrect size belt
2) Belt contaminated with some sort of fluid that leaked on it
3) Belt or compressor misaligned
4) Compressor siezing
5) AC idler pulley siezing
Hopefully it's a cheap and easy fix
Old Jan 16, 2006 | 02:09 PM
nightmarechevy's Avatar
I agree with bud.
Old Jan 16, 2006 | 08:38 PM
95ImpSS's Avatar
Hopefully, it's bud's #5 suggestion. That's the least painful option. Post up... Inquiring minds would like to know.
kha4079
Oct 29, 2018 04:38 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
FormulaZR
Sep 14, 2015 05:23 PM
Hpinnovate
Sep 4, 2015 02:28 AM
