brake line dummy
ok maybe i'm stupid here but i'm installing a set of stainless brake lines. i got the rears done now on the front i'm having trouble. i need pics of how you routed yours. i can see how to route it bu i need to see how you secured it. routing it like stock seems like it will rub.
I had the jackstands on the frame, but I did put a floor jack under the control arms to check the clearance with the front suspension both compressed and extended.
i think i got them good to go. it was more of a pain in the *** than i thought it would be. broke the same bolt on both sides. the one on the upper control arm. are those steel or cast? if its steel I'm gonna weld the bracket on.
Good question, not sure if they're steel or cast. Which bolt broke, the one that holds the brake line bracket?
