Battery Relocation to the bed.
Old Sep 24, 2008 | 02:47 AM
AmericanMuscle313's Avatar
Default Battery Relocation to the bed.
Has anyone relocated their battery to the bed of the truck? If so where did you get all the parts (kit)? I tried a search but nothing came up.
Old Sep 24, 2008 | 08:06 AM
Raffman's Avatar
There are plenty of battery relocation "kits". Summit, Jegs etc. I used an aluminum battery box from Speedway Motors and just bought the cables and terminals locally. The only drawback is dealing with the battery connections when you want to remove the bed for fuel pump access, other than that it helps to distribute weight better.
Old Sep 24, 2008 | 11:11 AM
7845's Avatar
Banned
i did and mine is under the bed. used 2/0 welding cable for suppy
Old Sep 24, 2008 | 01:52 PM
Thanks for the reply guys. Anyone have any pictures of their install?
Old Sep 24, 2008 | 10:33 PM
Wyttrash96's Avatar
I hate my cats
PM NORCAL TBSS. He did it, and it looked really good. I did the search, but his pics have been taken off photobucket. I did the relocation thang on my Olds, and if you're doing it, I reccomend using the heaviest gauge cable you can afford. It makes a huge difference. There's a lot of power loss when the battery is so far from the starter, so you wanna do things overkill. Low voltage sucks. Also, keep the grounds clean. And even though it's a pain in the ***, run a ground cable from the battery to the engine block. It's long, heavy, expensive, and may seem unnecessary since you can ground to the frame right beside the battery, but the block works so much better. Good luck, post up pics when it's done.
Old Sep 25, 2008 | 12:23 PM
litreddevil's Avatar
Banned
bluecajun did it asohis came out great and he has pic on here do a search.
Old Sep 25, 2008 | 12:27 PM
Banned
here you go
https://www.performancetrucks.net/fo...tery+relocated
Old Sep 25, 2008 | 12:42 PM
Dirty 30's Avatar
LS1Tech Whore
I dont have a pic yet but its on the bed on the right rear. U can see the cut off switch.
Old Sep 25, 2008 | 10:52 PM
Thanks!
Old Sep 25, 2008 | 11:10 PM
7845's Avatar
Banned
search the name Quik. youll see his battery box
