Bang for the buck engine upgrades - '03 Suburban 2500 Quadrasteer (LQ4 / 4L80e)
#41
Glad to hear it's back on the road! 330whp is probably approaching 400 crank when driven through a 4L80e, yeah?
Wow re: broken dyno. That due to weight?
Just to correct the record, you had provided measurements for your driveshaft a few posts earlier - do you know what the final measurements that were right were?
And the dyno brakes broke once a piece of the driveshaft hit it, and caused the rear tires to flat spot.
#42
Update: Shop says the driver side head has to come off if we want to pull the rear-most exhaust stud that's broken off.
If the heads are coming off... What should I do while they're off... LS7 lifters + lifter trays? Mill the 317s for higher compression?
#47
If the trims are pulling fuel, even with them being -10 to -18, the computer is always aiming towards stoich. That is how narrow band sensor work. It doesn't matter what the o2 sensor fuel trims say, no matter the values it is trying to go back to stoich. Be it positive 12 or negative 8, it will always adjust towards the stoich value in the calibration.
If the trims were like that stock with good sensors, good fuel, non skewed alcohol content (on flex fuel vehicle), then there is likely poor working fuel injectors leaking in extra fuel. Maybe even a somehow the fuel pressure was over 58psi causing the injectors to spray more fuel.
#48
Found some used 317s locally for $150 and yesterday they came back from the machine shop with s clean bill of health. Screwed up though by ordering main ARP studs - not head studs - to get them back on the truck, so now waiting for Thursday delivery of head studs. Hoping to get the truck on the road by Friday!
#49
Finally got the truck back yesterday. It's running, but throwing some codes and the AFR looked very lean - idling in the high 15s, low 16s according to the gauge, and never dipping below mid-14s even under moderate throttle. Going to drive it a bit today and try and do some data logging, but ran into a peculiar problem I didn't anticipate -
I bought one of the new fancy AEM widebands that can talk directly to HPTuners via the CAN bus by passing through signaling over the OBD2 port. ...
That's all well and good, but to my surprise apparently my 2003 truck doesn't support CAN - only PWM/VPW? It looks as though GM may have started adding CAN as a supported protocol in 2004 for these trucks? Ridiculous...
So now I guess I need to figure out how to pass an old-fashioned analog signal to HPT? Unless there's some way to add or upgrade my truck to support CAN protocols... How odd.
In terms of break-in, I'm also trying to debate what's reasonable. I haven't gone over 4000rpm yet especially since I could see LTFTs up above 20% with the first tune PCM sent me - very concerned about going too lean.
With the new cam, refreshed heads and valvetrain, etc - how should I break it in? Thanks!
#50
Being all roller it isn't nearly as important as it used to be back when you had flat tappet cams and lifters that had to mate. An oil changed after a few hundred miles as insurance in case there are any shavings that came off should do it. As to the tuning, ummm... good luck.
