Bagged and lowered trucks inside please!
Old Mar 18, 2004 | 11:52 AM
LOW2000's Avatar
Exclamation Bagged and lowered trucks inside please!
I always knew that this would become a problem since I first lowered my truck and i'm hoping someone has a solution. My e-brake cable lays on a brake junction block that is bolted to the drives side of the rear axle and the scary thing is that it is starting to wear through the soft brake line, the junction block and the e-brake cable itself. I was trying to think of some way to shield the junction because the e-brake cable is under too much tension to suspend it above it.
Has anyone else been able to fix this problem, i'm afraid that I am going to try to brake one of these days and not have any brake pressure.
Old Mar 18, 2004 | 12:34 PM
MacADaYear's Avatar
Im not sure which truck you have but...
What if you got a ebrake cable from an extended cab or HD or something like that which has a longer line... Then run it how you need to... ?
I dunno just a idea....
Old Mar 18, 2004 | 01:21 PM
LOW2000's Avatar
Possibly, i'm hoping someone has some simple ingenius cheap idea though.
What I dont think would work with that setup is that there is a bracket bolted to the bellhousing that locates the cable so I dont know if that will work.
Old Mar 18, 2004 | 09:48 PM
tranzfourmd's Avatar
Default simple solution
garden hose.
the black this industrial type.
cut a peice of it, wrap it around the line, and then zip tie the ends of it to hold it on. Tighten it really well. This stuff last forever and doesn't detroy easily from rubbing. Cheap, easy and quick. Black hose also makes it harder to see from a quick glance.
Old Mar 19, 2004 | 10:52 AM
MacADaYear's Avatar
tranzfourmd
wrb002
Aug 31, 2015 12:00 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
Ketis
Jul 23, 2015 12:37 PM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
