BAD MISS magicaly appears!
Old Apr 16, 2011 | 08:57 PM
Gadgetized's Avatar
Swap the coil around and see if it follows. Unhook a plug wire when it is running. If it doesn't get worse then you know where your miss is. If the miss doesn't follow the switched coil, check the wiring to the injector. You could get a noid light, or switch injectors around too.
Old Apr 16, 2011 | 09:08 PM
Ender06's Avatar
That's the plan but I can't get the good code reader till Monday. Its at the shop. Mine isn't extensive enough to tell me which cylinder is missing
Old Apr 17, 2011 | 10:00 PM
Ender06's Avatar
Well I found it....a piece of METAL in the top of injector 8. The filter is my only guess of where it came from.
Old Apr 18, 2011 | 05:08 AM
Gadgetized's Avatar
Good, glad to hear you found it.
lxcoupe
Sep 6, 2017 08:24 AM
95RCSS
Sep 18, 2015 01:14 PM
JFOLM
Sep 10, 2015 07:37 PM
Boyes50
Sep 8, 2015 12:06 PM
