antitheft lock code?
Old Oct 12, 2008 | 03:56 PM
lawazita's Avatar
Default antitheft lock code?
what up guys, i bought a nice screen radio but when i installed it in my truck it was lock.... i seen it working before but in mine it said lock.....is there any code i got to know to make it work or does the dealer only know how to fix this.? thanks
Old Oct 12, 2008 | 04:52 PM
02BlueStepside's Avatar
Factory radio? If so I remember hearing about the radios being vin locked. Probably have to have the dealer reprogram it.
Old Oct 12, 2008 | 04:55 PM
Truckshop's Avatar
that would be correct if it is 03 or newer. there is a big write up about it in the tech articles on full size chevy.
Old Oct 12, 2008 | 06:02 PM
viciousknid's Avatar
Where's the Beef?
I'm still stuck on the Screen Radio part.
If its aftermarket you can find a manual for it on the internet and it should tell you the default security code.
If that doesn't work then you'll have to ask the previous owner.
If it's some kind of factory unit you will have to take it to the dealer to get it unlocked.
Old Oct 12, 2008 | 08:01 PM
lawazita's Avatar
thanks guys i will tomorrow see what they tell me!!!! thanks again
Old Oct 13, 2008 | 10:35 PM
lawazita's Avatar
well i took the truck to the dealer to get the vin relearn for the nav unit...not succesful!!! did not work....got home real pissed. i started searching the internet and it says something about having to connect the anntena too ? i did not get the antenna ! ill have to look for it see if i find it.....does this sound right ? needing the antenna to make it work ? they didnt even mention nthis at the dealer
Old Oct 14, 2008 | 08:20 PM
Truckshop's Avatar
does everything else work except for the nav? if so then yes all you should need is the antenna.
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
Cammed4ever
Sep 30, 2015 03:38 PM
