anorther aif filter ?
Old Nov 22, 2007 | 08:41 AM
andrew383's Avatar
traveling mod
Talking anorther aif filter ?
has any one fabbed up a cone filter in a stock airbox? which flows better a panel or cone filter??
Old Nov 22, 2007 | 11:41 PM
budhayes3's Avatar
PT's Slowest Truck
I haven't seen a cone filter in the stock airbox myself, but the drop in filters seem to work well...combine that with your idea to get a Volant ram air scoop (or you could fab that up too), and the air tube from the box to the throttle body, and it should be a set up that works as good as any of the other CAI's out there. I believe that Amsoil makes a direct factory replacement dry filter also
FWIW, the TrueFlow CAI is a panel filter system, and they appear to be pretty well designed to me.
Old Nov 23, 2007 | 09:07 AM
andrew383's Avatar
traveling mod
well i have the airaid jr kit now(filter and tube),but i like to tinker with stuff
Old Nov 23, 2007 | 09:12 AM
andrew383's Avatar
traveling mod
the true flow is oil less rite? i had an aem brute force on my s10 and loved cleanin that filter
Old Nov 23, 2007 | 09:34 AM
budhayes3's Avatar
PT's Slowest Truck
Honestly I'm not sure if the true flow is oiled or not...hmmm
Old Nov 23, 2007 | 10:19 AM
andrew383's Avatar
traveling mod
all i can find on true flow is there foam so idk.so you think a panel will flow the same as a cone filter?
Old Nov 23, 2007 | 10:24 AM
Stoichiometric's Avatar
Depends on the surface area.
Old Nov 23, 2007 | 10:33 AM
andrew383's Avatar
traveling mod
i found a 4.5in aem cone filter. so how would one measure surface area on a cone??
Old Nov 23, 2007 | 10:39 AM
http://mathforum.org/dr.math/faq/formulas/faq.cone.html
Old Nov 23, 2007 | 10:46 AM
andrew383's Avatar
traveling mod
awesome thanks bro
