alternator going bad???
Old Feb 16, 2006 | 02:08 AM
ZEUS!!!!'s Avatar
Originally Posted by gmcandcaprice
mine did that then i was at the race track and around 5000-6000 rpm the alternator would die out and the battery light would come on so took it to autozone (autozone life time alternator) the tested it and it tested good but then i was askin some q's and imagine that their high tech alternator tester didnt load test the damn thinh replaced it and imagine that it worked like a charm
Thats what i would do, just go to auto zone, they can test your **** for FREE and tell you if it is the alt or bat
Old Feb 16, 2006 | 12:00 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
A-zone's bench tester does not detect diode issues. I had my 130amp alt checked numerous times (light came on for 10 seconds, then go off & back on continuously), they replaced it with a 105amp (light stayed on constantly), went back to a new alt from O'Reilly (same result as the first). I bought a BRAND NEW Delco unit @ wholesale cost ($183) through dealer hookup, and have not had problems since. Service tech told me that problem requires alternator rebuild, and that alt will eventually die. My bad alt lasted for one month with irractic volt readings, and quit charging one Saturday. I got to the dealer at 10am, and didn't leave until nearly 2pm.
I was a REMAN-believer until this started happening. Electrical components will get replaced with NEW components from this point forward. Just my $0.02.
Old Feb 16, 2006 | 12:18 PM
leochevy2001's Avatar
still happening. i notice the other day that with my truck in gear, stopped with the defroster on that my voltage went down again. i could actually see my headlights dim. once i turned off the defroster the voltmeter started to go back up. so now i am confused. is the problem still with the alternator or is the ac/heater?
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
dsbodley
Nov 14, 2015 09:46 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Chevy305
Sep 28, 2015 09:21 PM
