All rpo codes in one place!!
Old 01-21-2006, 05:58 PM
5.3AlmnBlk's Avatar
Default All rpo codes in one place!!
**2 Seat trim, leather
**C Seat trim, cloth
**D Seat trim, Custom Cloth
**V Seat trim, vinyl
5B5 Power windows and mirrors (MSRP = $738.00)
5G4 Provision for cab roof-mounted lamp (MSRP = $103.00)
5X7 Provision for body mounted warning lamp (MSRP = $98.00)Provides an instrument panel mounted switch and heavy duty electrical relay with hook-up terminal in the engine compartment for a body upfitter to connect a body mounted warning or emergency lamp. 40 amp nominal rating.
5Y0 Provision for body mounted lamp with hook-up wiring (MSRP = $88.00)Provides an instrument panel mounted switch and electrical hook-up behind the cab for a body upfitter to connect a body mounted warning or emergency lamp. 21 amp nominal rating.
6C7 Console, roof with reading lamps (MSRP = $55.00)
6P3 Camper Mirrors, remote control, power extendable, non-heated (MSRP = $238.00)
7Y9 Battery, Single 770 CCA (MSRP = $56.00)
7Z1 Horn, high note (MSRP = $20.00)
8B0 Batteries, 770 CCA with a 600 CCA auxiliary (MSRP = $190.00)
8C6 Alternator, 145 amp (MSRP = $140.00)
8E8 Bumper, front, painted Black (MSRP = $45.00)
8E9 Bumper, front, painted White (MSRP = $45.00)
8F2 Ornamentation, delete (MSRP = No Charge)Upfitter option.
8S3 Backup alarm (MSRP = $103.00)97 decibels back-up alarm.
8T7 Half shaft boot for 4x4 (MSRP = $150.00)
8V2 Jack and tools delete (MSRP = -$32.00 Credit)
8X1 Label, fasten safety belts (MSRP = W/A)
9G3 Suspension Package, off-road, for base décor vehicles (MSRP=$395.00)
9L4 Power supply, 12 volt (MSRP = $158.00)
9M4 Decal delete, tailgate (MSRP = No Charge)
9R0 Sound system, ETR AM/FM stereo with cassette (MSRP = $150.00) with Base Décor and (MSRP = -$81.00 Credit) with LS décorAM/FM stereo with cassette, no CD. Replaces the base radio.
9R0 Sound system, ETR AM/FM stereo with cassette (MSRP = -$81.00 Credit)AM/FM stereo with cassette, no CD. Replaces the base radio
9R1 Decal delete, Pick-up bed (MSRP = No Charge)
9R3 Sound system, delete (MSRP = No Charge)
9S1 Seats, vinyl bucket (MSRP = No Charge)
9V5 Paints, solid (MSRP = No charge) Woodland Green
9V9 Paints, solid (MSRP = No charge) Doeskin Tan
9W3 Paints, solid (MSRP = No charge) Wheatland Yellow
9W4 Paints, solid (MSRP = No charge) Tangier Orange
9X5 Trim override, Custom Cloth (MSRP = $285.00) with Regular Cab and split-bench seat, (MSRP = $360.00) with Extended Cab and split-bench seat
A31 Windows, power
A95 Seats, front reclining buckets
AE7 Seats, front 40/20/40 split-bench
AE7 Seats, front 40/20/40 split-bench, 3-passenger
AG1 Seat adjuster, power, driver 6-way
AG2 Seat adjuster, power, front passenger 6-way
AJ1 Glass, Solar-Ray deep tinted
AN3 Seats, front power reclining full-feature buckets,
AU0 Keyless entry, remote
AU3 Door locks, power programmable
B30 Floor covering, color-keyed carpeting
B71 Wheel flares
B85 Moldings, bodyside
BG9 Floor covering, rubberized vinyl
BVE Regular production accessory, Assist steps, chrome plated tubular, stainless steel.
BVS Regular production accessory, Assist steps, black coated tubular, stainless steel.
C42 Air conditioning delete, provides heater only
C49 Defogger, rear-window, electric
C5H GVWR, 6900 lbs. (3130 kg)
C5M GVWR, 6100 lbs. (2767 kg)
C5S GVWR, 6600 lbs. (2993 kg)
C7H GVWR, 6400 lbs. (2903 kg)
CJ2 Air conditioning, dual-zone, automatic
CJ3 Air conditioning, dual-zone, manual
D07 Console, floor
DE2 Mirrors, outside rearview, foldaway, manual, Black
DF2 Mirrors, outside rearview, foldaway, manual, camper-style, Black
DF5 Mirror, inside rearview, electrochromic
DK7 Console, overhead mini
DL3 Mirrors, outside rearview
DL8 Mirrors, outside rearview, manual folding, power, heated, Black
DNH Regular production accessory, Underseat storage
DPF Mirrors, outside rearview, power, heated, camper-style
E62 Pickup bed, Sportside
E63 Pickup bed, Fleetside
E95 Regular production accessory, Tonneau cover, black, soft.
EN6 Regular production accessory, Tonneau cover, black, hard, folding, lockable.
FE9 Emissions, Federal requirements
G80 Differential, locking, heavy-duty, rear
G86 Differential, limited slip, heavy-duty, rear
GT4 Rear axle, 3.73 ratio
GT5 Rear axle, 4.10 ratio
GU6 Rear axle, 3.42 ratio
K05 Engine block heater
K34 Cruise control
K47 Air cleaner, high-capacity
K68 Alternator, 105 amps
KG3 Alternator, 145 amps
KNP Cooling, external transmission oil cooler
LM7 Engine, Vortec 5300 V8 SFI
LR4 Engine, Vortec 4800 V8 SFI
LU3 Engine, Vortec 4300 V6 MFI
L33 Engine, Vortec 5300 V8 SFI
LQ9 Engine, Vortec 6000 V8 SFI
M32 Transmission, 4-Speed automatic
M30 Transmission, 4-speed automatic
MG5 Transmission, 5-speed manual
NB8 Emissions override, California, Massachusetts, New York or Vermont
NC7 Emissions override, Federal
NE1 Emissions, Maine, Massachusetts, New York or Vermont state requirements
NP2 Transfer case, floor-mounted shifter
NP5 Steering wheel, leather-wrapped rim
NP8 Transfer case, electronic Autotrac
NW7 Traction assist system, electronic
NYS 4-wheel steering
NZZ Skid Plate Package
P25 Wheels, 4 - 17" x 7.5" (43.2 cm x 19.1 cm)
PCJ Z71 Convenience Package 1
PCK Z71 Convenience Package 2
PDB Safe and Sound Package, includes (U2K) Sound system feature
PDG Texas/Oklahoma/Louisiana Base Package,
PDJ Texas/Oklahoma/Louisiana LS package, includes (K47) Air cleaner
PF9 Wheels, 4 - 16" x 7" (40.6 cm x 17.8 cm) brushed aluminum
PPB Regular production accessory, Pickup bed extender, brushed aluminum.
PUB Regular production accessory, Pickup bed protectors, Top side rails, Black molded
PY2 Wheels, 4 - 16" x 6.5" (40.6 cm x 16.5 cm) 6-lug chrome-styled steel
Q4B GVWR, 6200 lbs. (2812 kg)
QBX Tires, LT245/75R16C, on-/off-road, white outlined-letter
QCC Tires, P255/70R16, all-season, blackwall
QCJ Tires, P255/70R16, all-season, white outlined-letter
QGC Tires, P265/75R16, all-terrain, blackwall
QGD Tires, P265/75R16, all-terrain, white outlined-letter
QJM Tires, P265/70R17, on-/off-road, white outlined-letter
QJP Tires, P265/70R17, on-/off-road, blackwall
QNF Tires, P235/75R16, all-season, blackwall
QNG Tires, P235/75R16, all-season, white-outlined-letter
QNK Tires, P245/75R16, all-season, blackwall
QNL Tires, P245/75R16, all-season, white outlined-letter
R6G Sun and Sound Package discount not desired
R6K Texas/Oklahoma/Louisiana Package discount not desired
R7D Wheel flares not desired
SAF Spare tire lock
T96 Fog lamps, front
TP2 Battery, auxiliary heavy-duty, 600 cold-cranking amps
TR3 Grille, color-keyed surround
TRE Ship Thru for models C/K15703, C/K15903 and C/K15753 (MSRP = $125.00)Produced in Ft. Wayne Assembly and shipped to Ft. Wayne Fleet Equipment
U01 Lamps, 5 amber roof marker
U2K Sound system feature, XM Satellite Radio
UB0 Sound system, ETR AM/FM stereo with CD player
UB1 Sound system, ETR AM/FM stereo with CD and cassette player
UC6 Sound system, ETR AM/FM stereo with 6-disc CD changer
UE1 OnStar
UK3 Sound system feature, steering wheel mounted radio controls
UM7 Sound system, ETR AM/FM stereo
UQ5 Sound system feature, 4-speakers
UY2 Trailering wiring provisions, for camper, 5th wheel and gooseneck trailer
V43 Bumper, rear, painted step
V76 Recovery hooks, 2 front, frame-mounted
VTH Ship Thru for models C/15703 and C/K15903 (MSRP = $145.00)Produced in Ft. Wayne Assembly and shipped to Midway
VTT Ship Thru for models C/K15703, C/K15903, C/K15753 (MSRP = $240.00)Produced in Ft. Wayne Assembly and shipped to Buckeye Truck Equipment
VWB Ship Thru for models C/K15703, C/K15903 and C/K15753 (MSRP = $125.00)Produced in Ft. Wayne Assembly and shipped to Emmert Equipment
VWG Ship Thru for models C/K15703, C/K15903 and C/K15753 (MSRP = $165.00)Produced in Ft. Wayne Assembly and shipped to Monroe Truck Equipment
VWH Ship Thru for models C/K15703, C/K15903 and C/K15753 (MSRP = $220.00)Produced in Ft. Wayne Assembly and shipped to Masterack Truck Equipment
VWS Ship Thru for models K15753, C/K15903, C/K15953 (MSRP = $275.00)Produced in Pontiac Assembly and shipped to Buckeye Truck Equipment
VWY Ship Thru for models K15903, C/K15753, C/K15953 (MSRP = $100.00)Produced in Pontiac Assembly and shipped to Scherer Trucking
VYC Ship Thru for models C/K15903, C/K15753 and C/K15953 (MSRP = $115.00)Produced in Pontiac Assembly and shipped to Knapheide Truck Equipment
VYS Ship Thru for models C/K15903, C/K15753 and C/K15953 (MSRP = $100.00)Produced in Pontiac Assembly and shipped to Masterack Truck Equipment
VYU Snow Plow Prep Package
YF5 Emissions, California state requirements
Z71 Suspension Package, Off-Road
Z82 Trailering equipment, heavy-duty
Z83 Suspension Package, Solid Smooth Ride
Z85 Suspension Package, Handling/Trailering
ZX3 Suspension Package, Ride-Control
ZY1 Paint, solid
ZY2 Paint, two-tone
Old 01-21-2006, 07:32 PM
8ALTNG's Avatar
DAMB
Thats all i can say
Old 01-21-2006, 08:29 PM
gonzo 6.2's Avatar
Didnt see NHT vortecmax
Old 01-21-2006, 10:23 PM
PT's Slowest Truck
budhayes3's Avatar
I'm thinkin this should be a sticky
Old 01-21-2006, 11:13 PM
5.3AlmnBlk's Avatar
This info was even good for me now i know i have a z85/z82. Also if dont see another option in there post it up a new RPO this is from 05 model year or 04 i didnt fin one for 06 yet.
Old 01-22-2006, 02:31 PM
Yelo's Avatar
Missing:
LQ4 Engine, Vortec 6000 V8 SFI
GU4 Rear Axle, 3.21 ratio
HC4 Rear Axle, 4.65 ratio
MT1 Transmission, 4-Speed automatic (4L80e)
M74 Transmission, 5-Speed automatic (Allison 1000)
I'll probably think of a few more at some point....
Old 01-22-2006, 02:34 PM
gonzo 6.2's Avatar
M70= 4l70e
Old 01-22-2006, 09:41 PM
5.3AlmnBlk's Avatar
Originally Posted by Yelo
Missing:
This rpo code list goes for some hds but it will be missing some parts since its for a 1500 i can get one for the hds i think.
Old 01-22-2006, 09:44 PM
gonzo 6.2's Avatar
Since you brought this on yourself i hope you are adding all additionals to your list
Old 01-22-2006, 10:18 PM
SnakeOiler's Avatar
I assume these RPOs are for the 05 model year, considering that is the year of your truck, but if you want to add some that are not there from an older year (2002), here are some more:
B32 Rubber/Vinyl Floor Mats – Front
C60 Front Air Conditioning
D48 Power Mirrors
EVA Test DVT, EVAP Emission Requirement
FWI Fort Wayne Assembly
JC5 4 Wheel Disc Brake (6100-7200lb)
UN0 Radio – AM/FM CD Clock/ETR Autotone
UQ3 Speaker System – Perf. Enhanced Audio
UY7 Trailer Wiring Harness
VB3 Rear Bumper - Chrome
VG3 Front Bumper – Chrome
VR4 Trailer Hitch platform
VXS Vehicle Complete
V22 Grille Radiator, Chrome
V73 Fixed Antenna
XCJ Tire Front P255/70R16 WOL
X88 Conversion Name Plate Chevrolet
YCJ Tire Rear P255/70R16 WOL
YE9 Uplevel Décor
ZCJ Tire Spare LT245/70R16 WOL
1SB Preferred Equipment Package
1SZ Preferred Group Discount
Quick Reply: All rpo codes in one place!!
