alignment guide pins
Old Jun 10, 2015 | 04:28 PM
DAH32's Avatar
Default alignment guide pins
The alignment guide pins up on the frame that hold the alignment cams. They pop out it looks like. I got NAPA to get a couple of new ones and they had knarls on them like wheel studs. They appear to be a little large. Is that a tool that is needed to install these or can plyers work if you can get even pressure on both sides.
Thanks
Old Jun 11, 2015 | 03:26 PM
AUTOT3K's Avatar
are you talking about the molded plastic tabs that are inside the Eccentrics on the upper control arm?
those dont go back on when removed to adjust caster / camber. the torque of the bolt / nut is what holds it in place.
they're kinda like those metal retainers on the drums that come from factory, its for assembly purposes
Old Jun 11, 2015 | 08:16 PM
DAH32's Avatar
No, I dont think so.
They pop out of the frame. The replacements have knarls on them.
http://www.summitracing.com/parts/mo...FUslgQodJKYA4w
I think a C clamp and socket should get them installed.
They are not quite like the originals.
Old Jun 12, 2015 | 08:15 AM
AUTOT3K's Avatar
The link didnt work for me.
Can you take a pic of what you're talking about.
Did you have to remove the bolts then knock out a small chunk of metal so that the bolt can slide back n forth when turning the eccentric?
Old Jun 12, 2015 | 08:51 PM
DAH32's Avatar
Just google that. Silverado alignment guide pins.
No, once you look over the A arm. I think you will see how that works.
lukn4trbl355
Oct 21, 2015 11:19 PM
Silver8ado
Sep 30, 2015 11:42 AM
trxmxzx
Sep 29, 2015 07:42 AM
xxloudogxx
Sep 28, 2015 12:30 PM
kalikid06
Sep 20, 2015 07:46 PM
