airbag light on after engine swap
Old Nov 8, 2016 | 02:49 PM
silvy13's Avatar
Default airbag light on after engine swap
so i recently did a engine swap from a 5.3 to a 370 but now my airbag light is on? did i miss something or will i have to reset the light ..i have checked the airbag plugs under passenger seat and everything is connected.
Old Nov 8, 2016 | 02:57 PM
FFDP's Avatar
There are airbag sensors on the front of the truck too, behind the bumper area.
I'd double check those plug in's and wires.
Old Nov 8, 2016 | 08:28 PM
cheyenne383's Avatar
TOWN CRIER
Did you disconnect the steering shaft to get to the driver side motor mount? If you did it may have rotated the steering wheel and messed up the clock spring. Check grounds to the frame as well...
Old Nov 9, 2016 | 10:02 AM
silvy13's Avatar
i will have to check the sensors behind the bumper. i did not disconnect the steering shaft when i was installing the engine or when i was removing it.
Old Nov 9, 2016 | 12:50 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Start by getting the code pulled, that will tell you where to look.
It may just be an unfortunate coincidence.
