an AC nightmare, someone please help...
Old Oct 20, 2007 | 11:19 AM
1SICKhawk's Avatar
Default an AC nightmare, someone please help...
I am sure this is something most of you have had a problem with.
For the past week my ac has been acting crazy...shutting on and off, barely blowing, etc.. I have been on the move to figure out whats wrong, need some opinions.
Now when i turn it on i can def. hear the compressor kick on and shut off when i turn it off, so HOPEFULLY that's not the problem.
I have checked both the fuses and they are good.
So i have come to these conclusions i either:
Have a bad electrical connection somewhere down there.
or the switch has gone out, i took it somewhere and we took the panel under the passenger seat off (you know right where the ac is blower/motor is) and the motor would come on and off when it wanted or if i kinda moved it..
Do you guys think it might just be a switch?
When it does blow it's really cold, so i dont think it's low on freon..
Has anyone had the same problem?
I really dont want to replace the entire blower motor, cause things hardly ever go out.
Old Oct 20, 2007 | 02:59 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
sounds like a bad electrical connection to me, but other then that I have no idea, I know nothing about A/C
Old Oct 20, 2007 | 04:22 PM
truckmann's Avatar
It may still be low on coolant. Even though it blows cold if there is not enough pressure in the system the compressor will cycle like that. Could also be a bad low pressure switch.
Old Oct 20, 2007 | 05:45 PM
bigbadwolf54's Avatar
13 Second Truck Club
if its the blower motor itself turning on and off by , sounds like your blower motor resistor might be going bad/and more than likely the resistor connector is melted as well @ the resistor
Old Oct 20, 2007 | 06:00 PM
nonnieselman's Avatar
I had this problem.....
Check the resistor on the blower motor.... i think you will need a 5mm or 6mm socket?? its small
Old Oct 20, 2007 | 07:24 PM
its a 5.5mm or I think a 7/32 works too
Old Oct 20, 2007 | 09:09 PM
Wilde Racing's Avatar
How do I change this text
FYI, That is normal operation. It runs the A/C during defrost to help remove mosture and lube the A/C compressor during the "off season"
Is the fan not blowing or the a/c not getting cold?
Old Oct 20, 2007 | 09:29 PM
1SICKhawk's Avatar
sometimes it will blow barely, and then when i get on the highway or something itll blow like crazy for about 10 seconds and then shut itself off.
noproblems209
Aug 10, 2015 06:57 PM
CRAZYCUTER4.8
Mar 28, 2007 09:43 AM
Phatchevy
Jan 27, 2007 02:01 PM
Sport Side
Nov 7, 2005 10:34 PM
jow02327
11
Oct 30, 2005 01:13 AM
