AC HELP....stuck
Old Aug 5, 2012 | 03:30 PM
RST787's Avatar
Default AC HELP....stuck
I have a 90 c1500 that the ac blower that would sporadically work. I replaced the blower and had no problems for about a week. It then too stopped blowing all together. I then replaced the blower resistor and still no go. I then swapped the relays off my bosses identical truck and still nothing. I dont think its the control panel cause i can hear the relays switching. I also tried wiggling the connectors gently to see if possibly the connectors were loose. Any advice is greatly appreciated, im not enjoying this fl summer heat without my ac!
Old Aug 5, 2012 | 04:40 PM
JackJare9455's Avatar
Have u checked for power down by the blower motor or resistor?
Old Aug 5, 2012 | 06:21 PM
RST787's Avatar
tested for power at the blower motor and didnt find nothing. that was before i switched out the resistor. i also checked fuses and they are fine. ill check for power at the resistor. if there is none, whats the culprit?
