ac compressor, or ac clutch replacement ? 03 sierra
Old May 28, 2012 | 06:54 PM
jeffz0rz's Avatar
that sounds about right. wonder what a shop would charge to install and charge.... eliminate a possible headache for me.
Old May 28, 2012 | 08:49 PM
GMCtrk's Avatar
I looked into this because I thought my compressor was out, turns it wiring had burned up.
Anyways, I could do everything at home except drain the system and evacuate it prior to refilling. A local shop would have charged around $80 to do that stuff.
Old Jun 4, 2012 | 04:39 PM
06Sierra2's Avatar
Did u ever install the compressor? Did it fix the problem? I was looking at mine today and it seems like the belt more play on it than before. The belt is less than a yr old so I'm thinking the culprit is the tensioner. That would explain why it only makes noise when the compressor engages
Old Jun 9, 2012 | 07:24 PM
jeffz0rz's Avatar
****. i never thought about the belt being warn out. the ac started blowing hot yesterday, so today i swapped out compressors. when i first looked, i noticed that the ac belt was broke. i just went ahead and replaced the compressor. i never thought about the belt being bad. when it would kick on, it made a **** ton of noise for it to be just a old warn out belt. well either way, ive got cold ac now.
TX Tahoe Z71
Sep 1, 2015 09:11 PM
Ketis
Jul 23, 2015 12:37 PM
bsn1989
Jul 16, 2015 08:20 AM
rojeho
Jul 12, 2015 06:10 PM
