AC blows hot on pass side?
I did a search and turned up nothing - but I know I've seen posts on this in the past.
Basically, my climat control is blowing ONLY full hot on the passenger side, while drivers side is operating normally. Then I get in a second time and its only blowing out the defrost. I've had a new head unit installed last fall, climat senors replaced and checked all fuses. If I recall correctly, when it blows ONLY DEFROST its some sorta over-ride/failsafe mode? Haven't checked for codes yet...R/
PT's Slowest Truck
From what I've researched, it seems like the blend door actuators are prone to failure, just have to figure out which one. There is also a "park procedure", or "re-park", that resets the actuators, you could try that first. If you search for "actuator" or maybe "blend door motor", something should come up.
TX Tahoe Z71
09-01-2015 09:11 PM
