8.1L #7 misfiring
Old Dec 6, 2018 | 06:27 PM
Tinbender59's Avatar
Default 8.1L #7 misfiring
Hello everyone, I'm getting my ars handed to me and now I'm reaching out to you all for ideas, here's where I am at; new plugs, new wires, new coil, new cam sensor, new crank sensor, complete set of "different" injectors, swapped ECU. Performed a decarboning process (water and oil mixture) compression test, 150# on #5 & #7 didnot test compression any further.
I am now searching for the needle in the haystack.
How does the ECU determine a misfire?? Does it read the knock sensor and the firing sequence? If so it could be a flywheel bolt hitting,? ( I did not install the transmission, so I cant garantee anything). Could it be a restriction in the intake? Something on the top of the piston?
These 8100 are not cheap to work on so I really don't want to go all shotgun on it, I've invested a lot already.
Has anyone ever seen this before??
Old Dec 6, 2018 | 08:02 PM
wretched73's Avatar
What code is it throwing?
Did the misfire start out of the blue or did it start after you had trans work done?
Old Dec 6, 2018 | 10:08 PM
LA FEA's Avatar
Pull the vacuum line off the fuel pressure regulator and check if fuel is coming out of regulator also plug that vacuum line with finger and see if misfire goes away.
jus a quick check off the top of my head.
Old Dec 7, 2018 | 12:49 PM
Reckless's Avatar
Still moddin'
Also verify continuity on the wires between the injector and ECU. They are like a 4-strand wire and sometimes break internally when handled. I had to replace 3 on my old LS Formula. Long shot, but I had tried everything else.
CalSpeedPerformance
Nov 18, 2008 02:26 PM
beastmode
Apr 19, 2008 04:59 PM
hourang
Aug 25, 2006 08:21 AM
1SlowHoe
13
Jul 18, 2005 07:54 PM
Gen3
Oct 18, 2002 10:17 AM
