#5 setting on ac
Old Aug 19, 2007 | 08:40 AM
virgils4.85spd's Avatar
Default #5 setting on ac
is acting up. Every other level works fine until i turn it to #5. It will make a light click when i engage it and the blower wont come on for another 20 or 30 seconds. The compressor will engage when on #5 but the blower wont turn on for about 20 or 30 secs and then it works fine. Whats screwing up here? Somebody please help its drivin me crazy!!
Thanks,
Derek
Old Aug 19, 2007 | 09:14 AM
Raffman's Avatar
It's a resistor for the switch. Your GM parts guy should know about it , it's common for it to go bad. The replacement is a little different, so maybe its better.
Oh yeah its a breeze to change, mounted on the heater box under the dash.
Old Aug 19, 2007 | 09:19 AM
Wilde Racing's Avatar
How do I change this text
Number five setting (or the highest fan setting) is usally full power, or in other words, no resistor. that setting usally has it's own fuse, and relay. I'll see if I can find out for sure..
Old Aug 20, 2007 | 04:04 AM
viciousknid's Avatar
Where's the Beef?
5 don't seem to cool as well as 4 anyway.
Old Aug 20, 2007 | 11:23 AM
Default ok thanks guys
its just drivin me crazy! Just let me know what yall find out. I appreciate it!!
thanks,
Derek
Old Aug 20, 2007 | 11:33 AM
BlackGMC's Avatar
Resident Retard
Mine did the same thing and I brought in for warranty work and they said they replaced the switch and harness, whatever they did it fixed it.
Old Aug 20, 2007 | 11:39 AM
Grumpy5.3's Avatar
you need a resistor. Your #5 setting does go through it. pull it out and see if it is burnt up or has spots on it.
Old Aug 20, 2007 | 09:15 PM
litreddevil's Avatar
Banned
dude it also could be a control panel
Old Aug 20, 2007 | 09:49 PM
bigbadwolf54's Avatar
13 Second Truck Club
more than likely a resistor and harness if its burnt up...good luck gettin the harness though they've been on backorder for awhile
Old Aug 21, 2007 | 05:08 PM
TylerCustoms's Avatar
Yeha mine burnt right up, die-electric grease has it working temporarily
