I took the ABS fuse out of my tahoe after the ABS did that crap and i wrecked. I probably havnt had it in in atliest 3 years now. Everything works perfect except the ABS. I can actually stop faster in snow and rain that my friends tahoe with ABS because sometimes sliding makes you stop faster. ABS is not really designed to make you stop shorter, its designed to make you stop without ever losing control. Without ABS if you do try to stop fast in rain your truck will probably kick out sideways, but some of us like that.:D
mine did it and i got a recall in the mail saying that the abs sensor in the front would get a light layer of rust causing the sensor to become out of calibration...had the dealer clean in under warranty and not a problem, until about 2-3 years later...lol i just ignored it and it caught up to me! i pulled into my girlfriends house and the ABS turned on and POW! right into the back of her dads nissan titan...my truck didnt have a scratch but his needed a new bed side and bumper:(
so after that i took the sensor out and cleaned it while i did the front brakes and now the abs light is on...i dont know if you have to recalibrate it but it doesnt bother me...i love it w/o abs...much easier to drive in the snow thats for sure! id say take out the fuse or try to clean those sensors...worth a shot... BTW it would only really do it at low speeds and going over bumps like you mentioned... |
Mine used to do that when my shocks started getting wore out, with the new shocks, when I stop while going over bumps it does not do it anymore.
Where is the ABS sensor at so I can try cleaning it
Originally Posted by 00ChevyScott
(Post 4100657)
(Post 4100657)
shit mine will do it in a smooth road if you have to stop kinda fast it will do it nearly every time and that is not even getting on the brakes real hard so I know they should not lock up but the ABS still kicks in.
i have never had a problem with my abs. i avoid most bumps and potholes i see and dont normally do over the speed limit though (most of the time about 5 under)
Originally Posted by southern_chevy
(Post 4100671)
The purpose of ABS is to help you maintain control of your vehicle during emergency maneuvers and panic stops. |
Something else that can effect unwanted ABS activation is mis-matching tire circumference. GM says that anything 1/4 inch or more difference in rolling circumference can cause it. Would also cause AWD or Auto4WD t-case clutch problems.
