25k Maintene on NNBS
Old Dec 8, 2007 | 01:16 PM
ob_silverado's Avatar
Default 25k Maintene on NNBS
Hey guys I have 24k on my truck and am looking at doing 25k tune up. Not like it needs it but here what I was thinking what do you guys think?
Change Oil well obviously.(royal pruple)
Change tranny fluid: not sure if I just drain and fill with new filter or flush it and add new filter and sysnthetic. I am also thinking about a deep trans pan.
Transfer Case drain and feel.
Front and rear axles drain and fill with synthetic and add rear diff cover for better cooling. Mot sure which one
Add a higher capacity tranny cooler. Not sure which one.
New plugs and wire. Not sure which one.
New rims and tire probably
Anything I am missing.
Sorry for the spelling
Old Dec 8, 2007 | 02:16 PM
Leroy_454's Avatar
I cant see any reason you would need to change plugs and wires yet. They should last much longer. Other than that the synthetics are great and I would look into Mag-hytec trans and diff. covers.
Old Dec 9, 2007 | 11:18 PM
sleepersilverado's Avatar
sounds to me you are wanting to waste a lot of money. only thing i think you should do is the trans flush and oil change. call the dealer and ask i think the diffs and transfer case come with synthetic. If you open the transfer case and a clearish blue liquid comes out it is a special fluid. call and ask i think you are about to waste $$. but the diff cover and trans pan i like.
Old Dec 10, 2007 | 08:42 AM
shandy294's Avatar
I've read on this site that synthetic ATF is not recommended in these transmissions.
Old Dec 10, 2007 | 10:27 AM
CHEVRACER83's Avatar
the fluid in your trans and diffs now are long life fluids and are rated to at least 30k.... you have dexron VI in your trans no wand that has a way better service life than the old dex III and you may want to make sure the synthetics will be ok for your trans.... i would probably stick with the dexVI unless you hear different
Old Dec 13, 2007 | 08:24 PM
I guess i ll just flush the tranny and put trans and diff covers on.
AdaMax
May 16, 2016 11:35 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
Jr. SXT
Sep 30, 2015 07:23 PM
Gmc_sierra
Sep 13, 2015 10:02 PM
RONIN LSX
Sep 5, 2015 10:55 AM
