2002 gmc sierra gauge cluster to gen4??
Old Feb 8, 2013 | 03:17 PM
dane1586's Avatar
Default 2002 gmc sierra gauge cluster to gen4??
I am wanting to do a Gen3 to Gen4 engine and trans swap and was told that the Gen4 setup requires the gauge cluster to work properly. Is this correct and would a 2005 or 2006 gauge cluster be a direct fit for my 2002? Any help would be greatly appreciated.
Old Feb 9, 2013 | 12:44 AM
Suburbazine's Avatar
No, a 2003+ cluster will not work in a 2002- truck. The control system is different.
Old Feb 9, 2013 | 02:45 PM
dane1586's Avatar
I understand that the control system is different. I will be swapping out engine/trans/harness/pcm. I just need to know if the cluster will fit. I may be misunderstanding tho. Thanks for the help.
Old Feb 9, 2013 | 03:21 PM
Mangled03gmc's Avatar
Baltimore Whore
I am pretty sure it will fit in the mounting spot just not sure if the tabs, such are the same..
Old Feb 9, 2013 | 03:32 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Gen3 and Gen4 reefers to the engine and not the cluster or years of the truck.
Old Feb 9, 2013 | 04:26 PM
dane1586's Avatar
Yes. I was told that the transmission I will be running out of a Gen4 will need the same year model cluster to operate properly. If I'm understanding this correctly the trans has it's own computer that talks to the PCM thru the gauge cluster. Is this correct?
Old Feb 9, 2013 | 09:52 PM
dane1586's Avatar
Ok, found out what I'm looking for is the CAN BUS. Is it integrated into the dash cluster or is it mounted up under the hood? And am I correct in thinking that all this will operate ok in my swap without needing external controllers?
Old Feb 9, 2013 | 09:59 PM
1FastBrick's Avatar
A Gen 4 can bus system is entirely different.
Old Feb 9, 2013 | 10:55 PM
CANBUS and GM's CAN-D systems are ring networks. All for one, one for all.
You would have to perform a complete body harness swap with the Gen4 PCM, BCM and cluster. If you neglect one or miss a connection, the most common side effect is the car won't start anymore. (take Jaguar for instance- if the speedo fails, the car is dead!)
Old Feb 10, 2013 | 12:52 PM
dane1586's Avatar
Thanks!!! That's what I was needing to know.
