1998 5.7 Losing Only So Much Coolant ?
Old Jan 14, 2013 | 10:58 PM
therock's Avatar
Default 1998 5.7 Losing Only So Much Coolant ?
We have been looking at a 1998 Suburban with a 5.7 that drops its coolant level by about 6 inches and stops. Or it gets so slow we cannot see it.
Anyone?
Old Jan 14, 2013 | 11:13 PM
RacinRust's Avatar
Fill the cooling system full. Using a coolant system pressure tester, pressurize the cooling system. You should then be able to see the leak. They are bad about the intake manifold gaskets leaking coolant, but I would make sure its not a hose, radiator or front or rear heater core. Is your front passenger floor wet?
Old Jan 15, 2013 | 12:09 AM
therock's Avatar
We will look, Thanks!
Old Jan 15, 2013 | 05:48 AM
iamkeniff's Avatar
intake, or the heater core plug on the passenger side of the intake is common for that. check weap hole in the water pump also.
Old Jan 28, 2013 | 11:45 PM
Evil Eric's Avatar
I just want to throw my 2 cents in, the waterpump gaskets and the heater core line into the passenger side head have always been trouble on my k1500.
Old Jan 29, 2013 | 02:17 AM
Koots's Avatar
I'll also jump in with the rest for the intake gaskets and/or the heater pipe connector (or whatever it's called).
When the water pump on my 98 K1500 started spraying out of the weephole, it would run itself dry after a few hours. Otherwise the intake gaskets would drop it down to a certain level and remain there, as you have described.
Luckily, my intake gaskets were leaking externally, which is why it wasn't harming the engine or loosing coolant at a consistent rate.
Old Jan 29, 2013 | 03:11 AM
TIM Z's Avatar
11 sec. Truck Mod
Hmmmm, my dads 99 burb is doing the same thing , we are chasing loosing coolant , he had the updated gaskets put on bout 60 k ago, .
A tech recommended to make sure his rad cap was good , cheap to try so we got a new one and are going to see if it helps , seems to wet time to time around the rad core support , rad is not that old.
6.0l RST
Nov 23, 2015 11:30 AM
bearden86
26
Nov 15, 2015 03:58 PM
Gadgetized
Oct 22, 2015 09:06 AM
sTNT971
Sep 26, 2015 04:22 PM
FormulaZR
Sep 14, 2015 05:23 PM
