1500HD vs 1500 Suspension for putting back to stock
Registered User
I've researched and googled but keep coming up empty.
I have a 2wd LS 01 1500HD.
I want to lift it using lift spindles but do I use the regular 1500 spindles or try to find 2500hd spindles? I also need to replace the shackles because they put on those adjustable lowering shackles. So which truck do I get stock shackles from?
Like I said I've searched and searched but can't get an accurate answer. No one focuses on the front suspension but only the rear axle itself. So if anyone can guide me in the right direction it would be awesome.
Registered User
Originally Posted by FFDP
A 1500HD is a 2500 when it really comes down to it. It rides on a 2500 frame with that suspension and 8 lug wheels.
You need the heavy duty spindles and not the regular spindles.
Registered User
If you have 8 lug wheels and 4 bolt wheel bearings, then yes.
All the regular half ton trucks have 6 lug wheels and 3 bolt wheel bearing.
Parts for a 2500HD or 3500HD for that matter suspension, hub and brake wise in the front are all identical to your 1500HD. So buy appropriate parts which aren't for any non HD 1500 series truck.
