12 volt oil pump?
Old Nov 15, 2005 | 04:14 PM
Yellowsierra's Avatar
Default 12 volt oil pump?
I have been looking for a oil pump for a remote mount turbo setup for two weeks now! I bought a surflow but it will not flow enough oil. I need something that will flow 3+ gallons per minute. I was looking at a groco oil pump that pumped 4 gallons per minute but the person I talked to said he wasnt sure if it would last to long pumping all the time. If I could figure out what STS was using I would buy it but they wont tell me Does anybody know what I should use or If anybody knew what kind of pump STS used that would work good to.
Thanks
Yellow
Old Nov 18, 2005 | 02:04 PM
natural1's Avatar
Mocal makes a decient oil pump. I believe it is what STS is using, if not close. They are about $180.00 and they specify turbocharger oiling. Three gallons per minute? That is quite a bit. Two gallons per minute should be more than adequate, that is one half gallon every 15 seconds or one quart in 7.5 seconds. They are rated for continuious use and even have an internal fan.
http://www.racerpartswholesale.com/mocal1.htm
5.3Okasai
Mar 9, 2022 01:07 PM
pupi305
Sep 14, 2015 11:40 AM
JordanH
Aug 8, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
