05 6.0L MAF connector part #
Old Sep 24, 2006 | 02:02 AM
  #131
TURBHOE's Avatar
i need parts numbers for the sss front end. i got about all of them but i can't find the headlight brackets. and do i need the bumper mounts?
Old Oct 12, 2006 | 10:53 AM
  #132
beastmode's Avatar
Import Moderator
15002781 this is the part no. for the 99-06 silverado 2wd ubolt did anybody order these and know if you have to order 2 of em or if they come 2 in a pack?
Old Oct 12, 2006 | 11:23 AM
  #133
bigredexpress99's Avatar
you have to order 2 of the part number
Old Oct 12, 2006 | 11:28 AM
  #134
beastmode's Avatar
Import Moderator
thanks
Old Oct 13, 2006 | 04:01 PM
  #135
04BlackSilverado's Avatar
Part Numbers I came across through gathering parts for my swap......
These are for a 2006 Corvette so they are may not be the same as the GTO, TBSS, or SSR. Double check first please
LS2 (1) Intake Manifold 90mm 12589181
LS2 (8) Intake Gasket - Intake to Cyl Head 12580833
LS2 (1) Seal - Throttle Body Attach 12576549
LS2 (1) Sensor - MAP 16212460
LS2 (10) Bolt - Intake Manifold Attach 12552344
LS2 (1) Throttle Body90mm 12570790
LS2 (4) Fastener - Throttle Body Attach 11519971
LS2 (1) Fuel Rail 12572174
LS2 (8) Fuel Injector Asm 12569113
LS2 (8) Clip - Retainer 24503227
LS2 (4) Bolt - Fuel Rail Attach 12590276
LS2 (2) Cylinder Heads 12564243
LS2 (16) Valve Guides 10215342
LS2 (16) Intake Valve Seats 12598773
LS2 (16) Exhaust Valve Seats 12598775
LS2 (16) Valve Springs 12586484
LS2 (16) Valve Spring Caps 10166344
LS2 (8) Intake Valves 12563063
LS2 (8) Exhaust Valves 12563064
LS2 (32) Valve Stem Locks 10166345
LS2 (8) Intake Valve Stem Seal 12565208
LS2 (8) Exhaust Valve Stem Seal 12565209
LS2 (8) Spark Plug 12571165
You will also need a harness from Speartech to connect your truck TB connector to the 90mm TB.
And the TAC Module to control the 90mm TB 12574221
The pre 03 Trucks may already have this, look under the hood between the Brake Booster and the fender, its on the firewall with two connectors in the bottom of it. I had the 12573059 TAC and it will not work from what I hear.
I will be posting a thread about the entire swap when complete along with all the pics.....
Old Oct 24, 2006 | 12:43 PM
  #136
beastmode's Avatar
Import Moderator
03+ chevy tail light wiring harness. i need passenger side and driver side, not sure if there the same or not
Old Nov 9, 2006 | 10:10 PM
  #137
foxracingfreak's Avatar
ok maybe i am stupid but i have looked and looked for silver birch esky door handle and bezel and the tailgate bezel and handle #'s. anyone got those?
Old Nov 9, 2006 | 10:18 PM
  #138
I'll get you guys your numbers, but next time you need numbers or have a question try over here - https://www.performancetrucks.net/fo...d.php?t=376463
Old Nov 10, 2006 | 09:54 AM
  #139
LH - 16531401
RH - 16531402
Old Nov 15, 2006 | 07:26 PM
  #140
joehawkz71's Avatar
anyone know that part number for the awd/2hi/4hi/4lo switch! i need to get a new one! mine is crapping out on me i think....
