03 up console in a 99to02
A console from a truck or suv will work. If it is from a 99-02, it will bolt right up. If it is from a 03+, you are correct, you will need the glove box assembly. Make sure the glove box assembly is also from a truck that originally had a console. I have heard the colors are not a dead on match between the 99-02s and the 03+, I forget which one is lighter/darker. Also, if you don't know, there will be a slight gap where the console meets the dash because the 03+ dash bezel comes down a littler farther than the 99-02.
