Two nitrous plates, complete dry kit, HSW interface
Old Jan 13, 2015 | 02:48 PM
Scoggin Dickey's Avatar
Former Vendor
Default Two nitrous plates, complete dry kit, HSW interface
We've dug up a few new in the box HSW nitrous kits, plate conversion kits and dry shot interfaces while cleaning out our warehouse and we are selling them at HEAVILY discounted rates. See below! just call 800-456-0211 to order, extension 358 or 353. You can also PM me for PayPal info. These are first come first serve and are all brand new in the original packaging and original instructions.
THE ONLY THING LEFT ARE THE INTERFACE DRY SHOT CONTROLLERS!
The ever popular HSW interface for fuel and timing control with a dry shot. We have both the 3 wire MAF and 5 wire MAF versions. I have a couple of each of these.
3-wire version: $63.75 plus shipping
5-wire version: $68.00 plus shipping
Here is the HSW description on the interface:
Introducing the world's first Air to Fuel nitrous controller; The HSW Interface. With The Interface controller you can now easily fine tune your air to fuel mixture without the hassle of swapping fuel jets or worrying about the nozzle placement in relation to the MAF sensor on your dry nitrous system. In addition to full control of your A/F curve The Interface can also retard timing when your nitrous system is active, so you can now run full timing NA and make max horsepower & torque and then safely and easily pull timing when your nitrous system is activated. Unlike some other timing controllers The Interface will show the timing being pulled when using a scan tool, so no more worrying if the timing is actually being pulled. The Interface can be easily installed into a pre-existing nitrous system and includes a pre-made wire harness for a simplified installation
Examples of Using The Interface:
Running a Dry Direct Port
Running a Dry Nozzle after the MAF Sensor (or before the MAF Sensor in a poor location)
Running a Dry Plate Kit
Adding fuel to a Wet Direct Port Kit (instead of wasting time changing fuel jets around)
Adding a little extra fuel to a Wet Kit to cure any "Lean Spikes" upon kit activation
How Does The Interface Work?
The Interface makes Air to Fuel adjustments using your Mass Air Flow (MAF) Sensor. Simply program The Interface as to what size shot you are running (adjustable from 5 HP to 315 HP in 5 HP increments). Full control over the A/F curve is now possible, allowing fuel to be added or subtracted. Timing control is done with the vehicles IAT Sensor. The Interface has a built in Diagnostics Mode & Safety Features. If the Interface detects anything wrong with the MAF Sensor it will not allow the nitrous system to become operational and trigger a Service Engine Soon (SES) light until the issue is resolved.
Feature Set of The Interface:
Air to Fuel Control
Timing Retard
Top End Engine RPM A/F Correction (Addition & Subtraction)
12 Volt or Ground Trigger (for easy integration into a pre-existing N2O system)
Adjustable Delay feature to prevent an initial "Overly Rich" condition (Rich Spike)
Built in Safety Features & Diagnostic Mode
Old Jan 14, 2015 | 09:47 AM
1_bad94Camaro's Avatar
11 Second Club
Pm sent on 5 wire controller
Old Feb 16, 2015 | 09:15 AM
Former Vendor
bump!
Old Feb 17, 2015 | 12:28 AM
X_Racing1's Avatar
How would I know which one I need 2002 Silverado 5.3L?
Old Feb 17, 2015 | 10:51 AM
Former Vendor
Confirm by looking at your MAF, which will have 5-wires that year
Oobray
Jun 13, 2022 03:38 AM
Corvette454l88
Sep 1, 2016 01:24 AM
subeone
Aug 19, 2015 07:44 AM
Dezert1500
Jul 30, 2015 02:51 PM
