Trick Performance Turbo Manifold
Old Nov 22, 2015 | 09:25 PM
Chevyratracer's Avatar
Default Trick Performance Turbo Manifold
Trick performance T6 turbo manifold designed to fit a 99-13 chevy or gmc but will fit many other applications. Its cast stainless and is a really clean, easy way to mount your turbo. It also has a 46mm wastegate flange on it and I will include the crossover flange SOLD
I also have a s475 t6 1.10ar exhaust housing. New, never used. SOLD
Stainless exhaust flange and v-band for a s475. $45 shipped
5" to 4" stainless slip fit reducer.$25 shipped
Ford racing green top 42lb injectors. $180 shipped
100mm MAF 500 miles on it and it works great.$80 shipped
Titanium t6 turbo blanket, new SOLD
Attached Thumbnails Trick Performance Turbo Manifold-20151122_181158_resized-1-.jpg   Trick Performance Turbo Manifold-20151122_181232_resized.jpg
Old Nov 22, 2015 | 09:36 PM
abey15's Avatar
Originally Posted by Chevyratracer
Trick performance T6 turbo manifold designed to fit a 99-13 chevy or gmc but will fit many other applications. Its cast stainless and is a really clean, easy way to mount your turbo. It also has a 46mm wastegate flange welded on $600 shipped to the lower 48.
Man if u had the rest of the hotpipes, I'd be really interested!
Old Nov 22, 2015 | 10:22 PM
RS/SS 4.8's Avatar
10 Second Truck Club
If you can get some bends and pipe and have acess to a welder you can fab some up on the cheap. Thats what i did and have way less than a premade kit.
Old Nov 23, 2015 | 05:29 AM
gallo-lo's Avatar
Are you interested in a set of TT headers? Good quality not ebay stuff.
Lmk
Ty
Old Nov 23, 2015 | 08:23 AM
Choda's Avatar
Such a nice piece. Good luck man
Old Nov 24, 2015 | 06:45 PM
Lmk
Ty
I don't really want to try to fit twins, sorry.
Old Nov 24, 2015 | 07:39 PM
JordanH's Avatar
Restricted
I've got a brand new cam motion cam, spec'd LMR, some low mileage prc .675 springs, and ls7 lifters that I'll swap you for the manifold?
https://www.performancetrucks.net/fo...prings-540867/
Old Nov 30, 2015 | 12:09 PM
Bump.
Old Nov 30, 2015 | 03:33 PM
MileHighSierra's Avatar
How much would you be able to do a hotpipe kit with the Trick manifold? Thinking this would maybe be a better way to go than an On3 kit.
Old Nov 30, 2015 | 04:35 PM
A half way decent exhaust shop would be able to do a crossover and down pipe for a couple hundred or if your capable you can do it your self for less.
