Trick Performance Composite water/Meth Tank NNBS
Old Jan 31, 2017 | 03:20 PM
shaw_426hemi's Avatar
Default Trick Performance Composite water/Meth Tank NNBS
New never used, planned to run it as a stand alone meth tank but i decided not to. Tank has no fittings nor does it have the aluminum plate on the bottom for the battery tray (does have flush mounted nuts for battery tray plate to mount to). The fitting holes are there and treaded for -10AN fittings but they are not open, meaning you would just need to hit it with a drill quick to open them up. So it is a sealed tank now with no opening other than the top cap, but as i sad the holes are there and threaded just have to hit with a drill if you want to use the -10AN fittings there. It also has the nuts on the bottom to bolt a battery plate to in order to make it work with the extra battery tray in a 07-13 NNBS. $80 shipped.
text for fastest response 320-491-3435
Old Jan 31, 2017 | 05:32 PM
07Softail's Avatar
Good Deal there!
RT
