Trick Nitrous P gauge/controller and nitrous outlet plate 90
1 Post
Trick performance P-gauge - NEW IN BOX. This gauge does everything. P is the only gauge in the world that is a progressive controller with mutli-point ramping capabilities. Its computer processor controls the nitrous system completely including the heater. It is the world's first and only gauge that is completely graphical and digital, with state of the art computer screen display. Its fully programmable system can work on any single stage nitrous system. You simply program the unit to your nitrous system. P is not just a gauge, it is a controller as well. P controls the heater, shuts the nitrous system down; if you are running lean or low on nitrous or fuel pressure, progressive controller, window switch, TPAS switch, nitrous pressure gauge, shift light. A warning flash will let you know you have a problem and where that problem is. P will dispaly, your (nitrous, boost, fuel, or oil pressure), O2 reading, is the heater on or off, nitrous progressive level, rpm, inside or outside the window switch setting, wot activation. The full color graphic display allows you to control and monitor your nitrous system with just a quick glance at the face. You have 8 main viewing screens to choose from, with just a push of the control button. Fits any 2 1/16 gauge pod.
• Progressive controller (time or rpm based)
• RPM window switch
• Wide-Open-Throttle detection when used with factory TPS or WOT switch.
• Supports Fly-by-Wire TPS rising or falling
• 5 Point variable Progressive ramping (time or rpm based)
• Shift Light
• Rich / Lean Cutoff (when used with a wideband)
• Air/Fuel inputs Digital or Analog
• Multiple wideband capabilities
• Heater controller
• First gear lockout / delay
• 8 different Main Viewing screens.
• Programmable Power UP screen and Arm screen
• Multiple pressure choices
• Pressure display ( Boost, Nitrous, Oil or Fuel)
Not being made or sold anymore as far as I know.
I would like to see 400 out of it shipped as to that's what I paid when I got it it's not doing much of anything
I also have a single stage plate 90mm I have never used it's also just sitting around doing nothing I would like 200 out of that since I don't have jets or hardware.
Both I would like to see 600 shipped but toss me some offers. If need be I think I have a couple solenoids around again also new but they will be NX this is all stuff I just have never gotten around to using.
Paypal is fine questions. Email me at RRWfrank@gmail
• RPM window switch
• Shift Light
• Heater controller
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
