Torsion bar to coilover conversion, complete setup + air bags CHEAP
Old Jan 23, 2017 | 12:14 PM
ThatDudeOrion's Avatar
Default Torsion bar to coilover conversion, complete setup + air bags CHEAP
All coilover parts have been sold
All airbag parts still available
2x Firestone 267c 2500 pound, single 3/8 npt port bags
1 set of GM SUV 00-06 bolt on air bag brackets and all hardware. These have been cut down on an end mill to be the correct length (height) when used with the bags above, to have a ride height around a 5-6" rear drop, with a good amount of air pressure in the bag which should approximate the spring rate / ride quality of stock or lowered coil springs. Also the bag brackets have been machined in such a way that one is slightly taller than the other to correct that trademark drivers side chevy lean.
also comes with air line and all fittings to run to Schrader valves on the back bumper. I wasn't going to do a fancy air management system just for the back, since I was planning on using coilovers on the front.
All the above can be yours for $150 shipped OBO
Last edited by ThatDudeOrion; Jan 26, 2017 at 07:36 AM. Reason: deleting stuff that sold
Old Jan 23, 2017 | 09:59 PM
Jeebalow's Avatar
Do you have part numbers and pictures? I'm interested to know if I can make the shocks work in my application.
Old Jan 23, 2017 | 11:44 PM
Tried reformatting to make it more legible
Hey, I was able to find the parts list easily, so here you go!
Here's a copy of my invoice from summit, the total was like $1167, I'll sell all this plus the lower brackets from Atomic for $650 shipped OBO. This has everything but springs for the back, the shocks I picked for the rear were basically selected for like a 5-6" drop at ride height if I recall correctly. I was gonna do airbags back there. The front springs I picked are 850's, which seems light, but I put tons of time into researching and picking the spring rate based on the length of shock I picked and the plan to use the stud tops instead of the procomp adapter things. and I took weights of my Esky that I got at the commercial scales and. If there's stuff here you don't want or need, just let me know and we can negotiate on the price. I'm open to negotiation.
HAL-7888-110
Coil-Over Adjustment Tool, 2-Spanner Wrenchs, Non-Adjustable, with Thrust Bearings, Washers, Kit
$40.97 1 $40.97
AAF-ALL18571
Tapered Spacer, Steel, Natural, .500 in. Inside Diameter, .375 in. Length, Pair
$2.59 1 $2.59
ENS-9-9101G
Bushings, Bump Stops, Polyurethane, Black, Conical, 2 in. Diameter, 2.125 in. Tall, Universal, Pair
$8.97 1 $8.97
Front coilover shocks
HAL-DS303
Coil-Over Shock, Proma Star, Twin-Tube, 12.625 in. Extended, 9.500 in. Collapsed, Bearing/Bearing, Each
$159.97 2 $319.94
Rear coilover shocks
HAL-DS902
Coil-Over Shock, Proma Star, Twin-Tube, 23.750 in. Extended, 15.000 in. Collapsed, Eyelet/Eyelet, Each
$169.97 2 $339.94
HAL-SS110SDM
Shock Mount, Stud Conversion, Top, Proma Star, Kit
$36.99 2 $73.98
HAL-COM8T
COM Series Spherical Bearing, PTFE Lined, Steel, Each
$11.97 2 $23.94
EIB-08002500850
Coil-Over Spring, Powdercoated, 2.500 in. Inside Diameter, 8.000 in. Length, 850 lbs./in.Spring Rate, Each
$65.97 2 $131.94
DJM-RK2000
Rear Component Kit, Chevy, GMC, Kit
$159.97 1 $159.97
DJM-SE2000
Shock Extenders, Rear, 3 in., Chevy, Kit
$57.97 1 $57.97
ENS-9-9103G
Bushings, Bump Stops, Polyurethane, Black, Conical, 1.5 in. Diameter, 1.563 in. Tall, Universal, Pair
$6.97 1 $6.97
Old Jan 24, 2017 | 02:05 PM
twistedchevy's Avatar
pm sent
Old Jan 24, 2017 | 09:28 PM
Pics of all the parts can be seen here:
https://imgur.com/a/8eFXz
Old Jan 25, 2017 | 03:49 PM
ILuvJDM's Avatar
So that setup you listed for the front would have been a 3" drop from stock height? I'm looking for coilovers but can't decide on which shock to get and which upper mount to go with
Old Jan 26, 2017 | 07:37 AM
All airbag parts still available, details in original post, $150 shipped OBO for everything.
